New owner/operater needing help finding loads.
Discussion in 'Ask An Owner Operator' started by GATRUCKER28, Apr 9, 2014.
  1. GATRUCKER28
    GATRUCKER28 Bobtail Member
    Apr 8, 2014
    6
    Thanks Received:
    Lula GA
    Hello fellow drivers I am brand new to this forum but not to trucking I've been driving for 11 years as a company. I've pretty much squared everything away but how do I go about finding loads through companys?
    p.s. I run a flatbed.
  2. bad-luck
    bad-luck Road Train Member
    Nov 16, 2013
    3,300
    Thanks Received:
    6,064
    Baltimore, Maryland
    Where are you planning on running. Check the load boards best place to start
  3. freightwipper
    freightwipper Road Train Member
    Mar 24, 2014
    9,366
    Thanks Received:
    11,439
    OTR
    you could lease onto a company and they'll pay you anywhere from 65-85% of linehaul or offer you some flat rate CPM for all miles while hooked onto them.
    The real money would to run under your own authority but that also means you do all the work and take on more risk.
  4. GATRUCKER28
    Apr 8, 2014
    6
    Thanks Received:
    Lula GA
    Well I am currently located in Georgia but I plan on running the southeast.
  5. GATRUCKER28
    Apr 8, 2014
    6
    Thanks Received:
    Lula GA
    I would like to run under on my own name. I guess it depends if I can find steady work through someone.
  6. freightwipper
    Mar 24, 2014
    9,366
    Thanks Received:
    11,439
    OTR
    Low rates are in the SE, better not go into Florida unless it's for $4 a miles because you'll get garbage coming out
  7. GATRUCKER28
    Apr 8, 2014
    6
    Thanks Received:
    Lula GA
    Even as a company driver I never they never could get anything worth a #### out of there. I've talked to a few guys and unless I misunderstand them they said they made pretty good.
  8. vladrad
    vladrad Light Load Member
    Apr 5, 2014
    51
    Thanks Received:
    8
    What is risk working on your own authority and searching for loads on his own?
  9. spyder7723
    spyder7723 Road Train Member
    Mar 31, 2013
    15,471
    Thanks Received:
    25,075
    sarasota, fl
    More money invested equals more risk. Insurance rates have doubled, and even tripled in some cases compared to a few years ago. That's the biggest extra expense of having your authority. Ten years ago my insurance was just over six thousand dollars, today I know guys paying 18k and more.
  10. cnsper
    cnsper Road Train Member
    Feb 28, 2014
    5,869
    Thanks Received:
    27,421
    You can try Tennessee Steel Haulers out of Nashville for loads. I used to work on their phone system but have not dealt with the trucking side.
