New to using APU.
Discussion in 'Questions From New Drivers' started by Dsb0701, Sep 5, 2021.
  1. Dsb0701
    Dsb0701 Bobtail Member
    Sep 5, 2021
    Thanks Received:
    Hello all. This is the first trk I have had with APU. The model is a 2020 KW T680. When the trk is turned ON A/C in the bunk only blows from P/S vents. When trk is turned OFF and APU is running A/C only blows from the D/S vents. Is this normal, is there some way to change this, or is this just the way it is?? Thanks in advance for your time and concern.
  2. pavrom
    pavrom Road Train Member
    Apr 29, 2012
    3,185
    Thanks Received:
    7,305
    NE illinois
    I believe that the way it should work
  3. Dsb0701
    Sep 5, 2021
    Thanks Received:
    Ok thanks
  4. truckdriver31
    Sep 18, 2013
    6,989
    Thanks Received:
    8,352
    turn key to the left and have all vents blowing. better noise damper and better air flow
  5. Moose1958
    Moose1958 Road Train Member
    Dec 17, 2010
    15,171
    Thanks Received:
    33,415
    Williesburg, Virignia
    I was always my experience the vents used by the APU AC were always in the sleeper. I always had plenty of air!
  6. tscottme
    tscottme Road Train Member
    Jul 25, 2008
    14,295
    Thanks Received:
    27,489
    Somewhere out West, in my mind.
    I don't know what is meant by P/S vents and D/S vents. The APU only blows cold air into the sleeper. When parked, turn off the truck's dashboard air conditioning system or you will just be filling the truck with hot/moist air.
  7. Moose1958
    Dec 17, 2010
    15,171
    Thanks Received:
    33,415
    I think P/S vents and D/S vents are shorthand for Passenger Side and Driver Side!
