Not a tech, nor do I play one on TV, but I have a question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Commuter69, Feb 2, 2021.
  1. Commuter69
    Commuter69 Road Train Member
    Jul 2, 2014
    1,137
    Thanks Received:
    632
    As a driver.....
    Last week, I was driving and my "check engine" light came on. I thought, 'oh crap, what now?'..
    At my next stop, while getting fuel, I popped the hood to look for any obvious reasons. Besides needing a little coolant and WW fluid, which I added, I found none. I turned off the master power while doing this, and nothing worked.
    Fast forward 4(?) days and a couple thousand miles, the light went out. No codes, no change in performance.......
    I am wondering what the cause could have been?
  2. Goodysnap
    Goodysnap Road Train Member
    Jul 12, 2017
    3,724
    Thanks Received:
    9,054
    Too many possibilities. Hooking up will give an idea. I would keep running it and pay attention to operating conditions when the light occurs. Its one thing of many I have learned that trucks dont fix themselves. Its still broken, just not right now.
    That being said, sometimes it is easier to wait until the light is on or the fault is active to dive into troubleshooting.
    Appears as though your issue has fixed itself.......for now.
    p608, BoxCarKidd and Muddydog79 Thank this.
  3. Evil_E
    Evil_E Heavy Load Member
    Nov 25, 2011
    790
    Thanks Received:
    537
    Dexter,MI
    Paccar will do that if it sees a drop in fuel pressure. Like filter is getting plugged or the o-ring on the secondary filter got damaged upon install.
  4. Commuter69
    Jul 2, 2014
    1,137
    Thanks Received:
    632
    2019 freightliner?
  5. Evil_E
    Nov 25, 2011
    790
    Thanks Received:
    537
    Dexter,MI
    Was it really cold then? Last PM done?
  6. Commuter69
    Jul 2, 2014
    1,137
    Thanks Received:
    632
    No, and less than 5000 miles(1/20 @ 361,000; now 366,000)
  7. Evil_E
    Nov 25, 2011
    790
    Thanks Received:
    537
    Dexter,MI
    I don't claim to be any kind of mechanic either lol. I guess if it ain't broke...probably charge you at Freightliner to hook up the computer and check it out
  8. McMahons Trucking
    McMahons Trucking Light Load Member
    Jul 4, 2018
    274
    Thanks Received:
    119
    I have a Mack and sometimes when it's cold out (which you said it wasn't) I will get the SCR BS because it doesn't get hot enough on the road for a regen.
  9. Mike250rs
    Mike250rs Heavy Load Member
    Sep 24, 2019
    881
    Thanks Received:
    7,080
    Raleigh, NC
    I could be as simple as too much water in the fuel..
  10. Coolbreezin
    Coolbreezin Medium Load Member
    Jun 11, 2016
    402
    Thanks Received:
    418
    Florida
    Could be similar to modern cars. They will sometimes throw an engine light while running self check tests.
