Odometer doesn’t lie, will they take care of the extra charges?
Discussion in 'Ask An Owner Operator' started by YoungBloodTrucker, Mar 10, 2021.
  1. YoungBloodTrucker
    YoungBloodTrucker Bobtail Member
    Feb 10, 2016
    38
    Thanks Received:
    19
    What’s going on truckers YoungBlood here with a scenario.
    Took my truck into a major repair shop on the 27 of Feb for a valve adjustment. Called in that Tuesday morning March 2nd shop said “Come on down mechanic down a road test on the truck should be ready by time you get here.”
    Picked up, went to the yard down the street parked. 3 am time to roll.... Check engine light is on...figure once start rolling it’ll turn off. Go approx 78 miles then red engine light comes on “100% derate , shut engine down immediately!!” I do as such...
    Tow back to shop.. I check my ELOG to see... Milage from pick up the same from drop off. Calls Safety to ask any movement of truck while in shop ? None only 1 mile.
    Called shop “You guys do a drive test before I pick up from valve adjustment ?” Shop: “Sure, did took it up the freeway check the jake brakes made sure everything been running good” end of conversation....
    Tow Bill $1200
    DEF Heat Sensor ~$500
    Labor ???
    Figure sensor gon get paid regardless, can I ask Truck shop to pay for tow and take some off labor since ELOG proves no DRIVE TEST was preformed and Tow could’ve been prevented ?? Thanks
    feldsforever Thanks this.
  2. aaronpeterbilt3787
    aaronpeterbilt3787 Medium Load Member
    Apr 2, 2016
    699
    Thanks Received:
    1,077
    Get printout of your logs for proof they didn’t road test. Go right to the owner of the shop. Bypass service manager completely. Seeing as how it took 78 miles for new problem to pop up, I’d say you’re SOL on getting reimbursed anything. But at least make owner/general manager aware of them lying to you. I hate being lied to when it comes to servicing.
    feldsforever, 77fib77, alds and 3 others Thank this.
  3. LoneRanger
    LoneRanger Road Train Member
    Jun 3, 2018
    3,675
    Thanks Received:
    9,544
    Funny how you take it in for one issue and end up having more issues right out of the gate.
    You can print it out or show the screen to the owner but it most likely won’t help you.
    finding a reputable mechanic is worse then finding a reputable driver.
    feldsforever, 77fib77, Badmon and 4 others Thank this.
  4. Ridgeline
    22,451
    Thanks Received:
    117,440
    When does a mechanic need to take a truck for a test drive after a valve adjustment is done?
    I would think these problems were going to happen no matter what.
  5. magoo68
    magoo68 Road Train Member
    Jun 11, 2011
    3,393
    Thanks Received:
    5,385
    st malo mb canada
    Shop will say why did you leave with a check engine light ?? And then say it was fine when they parked it . PS that’s a out of service if you get inspected and they find soot everywhere
    Reason for edit: Add something
  6. nikmirbre
    nikmirbre Road Train Member
    Jul 27, 2011
    5,439
    Thanks Received:
    9,848
    High Point NC
    I think with the soot issue, you’re talking about the other thread. Guy opened his hood and finding black ash everywhere :D
  7. GreenPete359
    GreenPete359 Road Train Member
    Oct 21, 2017
    2,152
    Thanks Received:
    5,101
    Driving my recliner
    one problem has nothing to do with the other. Why is it people always want to blame their problems on the mechanics?
    Having an over ran has absolutely nothing to do with your def system. Yet you want the shop to cover your operating expenses.
    personally, you bring that b.s. into my shop & you can pay to tow your truck right back off my property & to another shop. I would cut ties with you & refuse the work.
    Czar_Zero, Bo Hunt, tommymonza and 4 others Thank this.
  8. aaronpeterbilt3787
    Apr 2, 2016
    699
    Thanks Received:
    1,077
    And what about lying bout the test drive? I’m not saying the def issue is related to the valve set being done. But I HATE being lied to about anything.
  9. abyliks
    abyliks Road Train Member
    May 2, 2010
    3,924
    Thanks Received:
    9,188
    ludlow MA
    running the overhead and loosing a valve after I would be pissed and fight it, but on a problem that is completely unrelated and not even in the same area as the work that was done, welcome to trucking.
    $1200 is steep for a tow if it was that close as well
  10. slow.rider
    slow.rider Road Train Member
    Apr 4, 2017
    2,005
    Thanks Received:
    4,740
    NYC
    It didn't take 78 miles. He was down the street.
