Over on steer axle
Discussion in 'Questions From New Drivers' started by Erjonb, Jul 8, 2020.
  1. Erjonb
    Erjonb Light Load Member
    Aug 27, 2019
    56
    Thanks Received:
    4
    I started to drive a volvo vn 780 d13, and wanted to know how much is the limit on steet axle for this kind of truck? Bc if it's 12000, everytime a get scaled, im over. I moved the fifth wheel, but still. Thanks and be safe
  2. daf105paccar
    Apr 15, 2012
    6,564
    Thanks Received:
    7,293
    Start by checking the rating on your tires and steeraxle.
  3. Erjonb
    Aug 27, 2019
    56
    Thanks Received:
    4
    Thanks, but any chance limit can be 13200? That's what someone told me
  4. ZVar
    ZVar Road Train Member
    Sep 10, 2010
    10,911
    Thanks Received:
    23,830
    Flint, MI
    It can be. Volvo I'm in right now is 13,200 for the front axle. The rating is on the door jamb.
    12,000 is simply a rule of thumb so if trailer and drives are both fully loaded at 34,000 each you can only have 12,000 on the steers before your over the 80,000 lbs limit. Things never work that way in real life. There are a few things to look at for the axle weight.
    1. Tire ratings - on the tire
    2. Axle ratings - driver door jamb
    3. State ratings - front of your atlas
    It's the lesser of the three.
  5. bad-luck
    bad-luck Road Train Member
    Nov 16, 2013
    3,359
    Thanks Received:
    6,212
    Baltimore, Maryland
    Generally, having the 5th wheel in between the drives is where most people keep then5th wheel. Sliding it back should get some weight off of the steers.
    Numerous states allow the weight rating on the tires for the steer axle. For instance, I run 16 ply which are rated at 13,200. Hope this helps
  6. Erjonb
    Aug 27, 2019
    56
    Thanks Received:
    4
    Okay thanks
  7. Erjonb
    Aug 27, 2019
    56
    Thanks Received:
    4
    I had another volvo before this one and both trucks had fifth wheel all the way on front, and i never was over with that one, rn i have 40k pounds and steeraxle is 12220 pounds even tho i moved it one hole. Thats why im asking, I don't get it
  8. bad-luck
    Nov 16, 2013
    3,359
    Thanks Received:
    6,212
    Baltimore, Maryland
    A few holes back you will be legal.
  9. Bill51
    Bill51 Road Train Member
    Jul 27, 2015
    1,184
    Thanks Received:
    2,982
    [​IMG] repeating.
    Both the manufacturer's front axle rating and the tires BOTH should meet the specs for the weight.
    As quoted, if one or the other is rated lower, the lower rating is the steers weight limit.
    ZVar Thanks this.
  10. Capacity
    Capacity Road Train Member
    Jul 28, 2019
    1,499
    Thanks Received:
    3,119
    Neenah Wi
    We ran bus tires on our heavy tour on a standard 12k front axle
