pcv filter issues on isx
Discussion in 'Volvo Forum' started by axehandle, Aug 5, 2014.
  1. axehandle
    axehandle Bobtail Member
    Aug 5, 2014
    17
    Thanks Received:
    5
    Have vovo with isx threw pcv pressure codes. replaced filter and sensor after 10,000 miles started doing it again. filter again saturated with oil. whats .causing this and whats the fix. Thanks
  2. Bandaid
    Bandaid Light Load Member
    Feb 21, 2012
    114
    Thanks Received:
    60
    Union, Mo
    How many miles on engine? How many on turbos? When was your last overhead done? It is from excessive crank case pressure most likely.... I had this issue too, blown turbos, and worn valve guides were my issue.
  3. axehandle
    Aug 5, 2014
    17
    Thanks Received:
    5
    795000 on engine. Just bought truck so don't know history. Good oil pressure doesn't use oil. Half gallon low on way12000 since changed. Someone said egr system could be dirty causing pressure. I don't know hope it not internal problems
  4. Pahrump
    Pahrump Medium Load Member
    Jul 27, 2014
    453
    Thanks Received:
    392
    Grand Tetons When I took The Pic
    you are getting a lot of blowby,,,possibly you have a high mileage engine.
  5. axehandle
    Aug 5, 2014
    17
    Thanks Received:
    5
    Is this filter clogging common
  6. Bandaid
    Feb 21, 2012
    114
    Thanks Received:
    60
    Union, Mo
    On isx? The isx in my last truck only did it before the turbo blew.... my cat did it when the valve guides and turbos were getting ready to let go..
    If you have the know how, I pulled the turbo piping amd checked for oil in the turbo compressor and turbine... Check for shaft play as well.
    And like Pahrump stated, mabey the engine has high run/idle time causing large blow by.... do you do oil samples?
  7. axehandle
    Aug 5, 2014
    17
    Thanks Received:
    5
    No oil samples. Do idle a lot. With that much blow by wouldn't. It use lot of oil
  8. Bandaid
    Feb 21, 2012
    114
    Thanks Received:
    60
    Union, Mo
    It would burn a bit of oil..... that is why I was leaning toward the turbo/valve guides.... that problem for me showed a slight increase in oil usage... but was not near enough for me to worry..... hopefully someone else can throw their knowledge in to help more
    And yes egr could be leaking... but that would be showing other issues from what I remember.... and i don't think that causes enough crankcase pressure to saturate the ccv filter.
  9. axehandle
    Aug 5, 2014
    17
    Thanks Received:
    5
    Thanks sounds serious
  10. axehandle
    Aug 5, 2014
    17
    Thanks Received:
    5
    Would I only pull tubing on exhaust said of turbo
