Peterbilt 359 low air sensor location
Discussion in 'Peterbilt Forum' started by Hogleg, Nov 24, 2016.
  1. Hogleg
    Hogleg Medium Load Member
    Nov 20, 2016
    311
    Thanks Received:
    258
    Salem, Illinois
    Where is it located.
    Also, the indicator light is a large box back of the panel. Was thinking it would only be a light mount. Is this a light and a buzzer? How do I test it. How are the bulbs replaced? From the front or the back. On an old truck, plastic gets brittle. Don't want to pull on them too much and break something.
    Also, I have 2 light sockets marked Air. Is that corrrect?
    Thanks for the help. This forum is great. Been searching for most of my questions but this one came up blank.
    John
  2. noluck
    noluck Road Train Member
    Jun 10, 2011
    1,616
    Thanks Received:
    11,683
    greenville,sc
    I think the pressure switch is located at the bottom kick panel under the steering wheel. If I remember right it's in an aluminum block. There will be a few pressure switches there. Like for brake light switch and stuff. At least I think that where they are on my '89 379. Behind the plastic panels bottom drivers side
  3. Hogleg
    Nov 20, 2016
    311
    Thanks Received:
    258
    Salem, Illinois
    I will look for the aluminum block. It shows that on the air supply schematic in the service manual I just bought. On the 359 there is no panel on the left side of the wheel, just an open hole with wiring connectors. On the right side of the wheel there is a large white plastic cover. Will take a look there.
    Still need help on my other questions. Narrowing down the list of stuff to fix for the DOT inspection.
    John
  4. noluck
    Jun 10, 2011
    1,616
    Thanks Received:
    11,683
    greenville,sc
    It will be to the right of the steering column. If it's there I can't help with the buzzer and light. That's different from a 379.
  5. maggard359
    maggard359 Medium Load Member
    Nov 20, 2013
    476
    Thanks Received:
    413
    Florida
    Open hood, on drivers side near top firewall you will find a plate that has 4 bolts. Remove 4 bolts and it will expose the aluminum block that will have pressure sensors. I don't recall exactly which one it is but follow the wire from the air light on dash back to that pressure valve.
    Hogleg and noluck Thank this.
  6. Hogleg
    Nov 20, 2016
    311
    Thanks Received:
    258
    Salem, Illinois
    Thanks much, Maggard359!
    How do I check and/or replace the bulb in the air light. Does it unscrew out from the front?
    John
  7. Hogleg
    Nov 20, 2016
    311
    Thanks Received:
    258
    Salem, Illinois
    Also, my cluster of lights have 2 marked AIR. Which position is the AIR light supposed to be in?
  8. maggard359
    Nov 20, 2013
    476
    Thanks Received:
    413
    Florida
    I'm not sure on bulb removal I have never had to change one. I do know the buzzer is built in to the light part. Unscrewing face nut will only remove assembly. proper air location is on left.
  9. Hogleg
    Nov 20, 2016
    311
    Thanks Received:
    258
    Salem, Illinois
    Left one was correct. Now working.Thanks much.
    Can you tell me in clockwise direction what the other lights are? I have 6 on a corvette dash. From the top, we have diff lock, water (mid right), air (lower right, incorrect), green down arrow (bottom center), red unmarked (lower left) then air (mid left).
    John
  10. beemergary
    beemergary Light Load Member
    Apr 11, 2014
    229
    Thanks Received:
    112
    Got to follow wires. One should be the differential lock. Like Maggard said. too hard to work on switches without lowering steering wheel. Take off plate
