peterbilt 379 four way relay
Discussion in 'Peterbilt Forum' started by TURKER, Oct 8, 2009.
  1. TURKER
    TURKER Medium Load Member
    Aug 11, 2009
    344
    Thanks Received:
    97
    Raleigh NC
    Can anyone tell me where can I located signal relay in 2000 peter 379?It was working fine I installed new steering plastic shroud ,after that my 4 way and signals quit working.I did take out the shroud and check for the kink,cut wires-none check the fuse -OK. please help thanks If you know the part # it will help
  2. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,775
    Thanks Received:
    6,212
    I think it is in that neck of the woods. I think it is more behind the tach/speedo cluster.
    TURKER Thanks this.
  3. pullingtrucker
    pullingtrucker Road Train Member
    Dec 21, 2008
    1,185
    Thanks Received:
    598
    Fostoria, Ohio
    Yep its behind the tach and speedo...along with some other relays.
    TURKER Thanks this.
