2007 peterbilt 386 lose of power to cb, power windows, dome lights, cig lighter, blower motor fan, goes on and off...cb makes clicking noise when power is lost...does anyone know what is causing this and what to check? Thank you for any help you can give me.
Check all battery connections first , second check the fuse box at the fire wall by steering shaft. Check that the hot wire is tight.
I am having a similar issue with my 2009 Pete 386. Lost all my dome lights, floor courtesy light, and my cigarette lighter is working but not unless you play with it. Where exactly is the low voltage disconnect located? That would be a good place to start my search. All fuses are tested and good.
i am having issues with a 386 Peterbilt with a caterpillar C15. this one turn off after a minute to be on. i need help!!!
