Peterbilt 387 C15 ACERT have fault codes popping up. Please help.
Discussion in 'Peterbilt Forum' started by Big Al The Go-Getta, Mar 6, 2013.
  1. Big Al The Go-Getta
    Big Al The Go-Getta Bobtail Member
    Mar 6, 2013
    4
    Thanks Received:
    Hi, I have tried googling these codes and with no luck hope to hear any answers here. Maybe someone had similar issues or is a heavy duty mechanic? Any help would be greatly appreciated! I have the following codes on my peterbilt 387 with a C15 ACERT engine.
    (1)- 128 030 5 SID
    (2)- 128 031 5 SID
    (3)- 128 032 5 SID
    (4)- 128 129 1 PID
    (5)- 136 231 9 SID
    (6)- 000 002950 5 SPN
    (7)- 000 002951 5 SPN
    (8)- 000 002952 5 SPN
    (9)- 000 000385 1 SPN
    If anybody knows any of these please help me out.. Thank You in advance!
  2. mavljc
    mavljc Bobtail Member
    Jan 9, 2013
    44
    Thanks Received:
    24
    Check this place out www.topix.com/forum/com/cat , look up a guy called "Ken Mech" he is a cat mechanic that helps a lot of people out.
    Big Al The Go-Getta Thanks this.
  3. Big Al The Go-Getta
    Mar 6, 2013
    4
    Thanks Received:
    Thanks a lot! That's a very helpful place! Haven't had time today but I'm gonna look him up tomorrow...
  4. bstromback2002
    bstromback2002 Light Load Member
    May 12, 2012
    133
    Thanks Received:
    24
    wi
    I have the OEM service manual with me in the truck at all times if you don't get a answer from anyone let me know and I could message you my number and I could look them up for ya. That would be just too much info for me to try to type from my phone.
  5. bstromback2002
    May 12, 2012
    133
    Thanks Received:
    24
    wi
    to the best of my knowledge since im not sure how u got those type of codes here is what i show in my book.
    6 iva 1 current low
    7 iva 2 current low
    8 iva 3 current low
    and thats all i can help you with i dont see any of the other ones in the book.
    what year is the truck and what is the engine serial number???
  6. bubbanbrenda
    bubbanbrenda Road Train Member
    Feb 27, 2011
    1,388
    Thanks Received:
    650
    Middletown,Oh.
    double post
  7. bubbanbrenda
    Feb 27, 2011
    1,388
    Thanks Received:
    650
    Middletown,Oh.
    1),2), and 3) are injector codes, 4) is injector metering rail code, 5) is ABS code (I think), 6),7) and 8 are iva codes, can't find anything on 9) but they all are under the valve cover (except 5) sounds like a engine wiring harness to me, its pretty much plug and play, if its got more than 7-800,000 miles on it it probably needs a harness they are notorious for going bad.
  8. Big Al The Go-Getta
    Mar 6, 2013
    4
    Thanks Received:
    The truck year is a 2005 and the serial # is MXS09066. I asked my local dealer and he said these codes were not any codes that he could describe or explain. I got them from a computer scanner I bought for trucks.
  9. Big Al The Go-Getta
    Mar 6, 2013
    4
    Thanks Received:
    Well my injectors seem to be working fine, the truck engine runs smooth and strong. I am however having engine brake issues. Sometimes it works good but sometimes it super weak if not working at all. I have heard about the wiring going bad and I also think that could be at least part of my issues. S I'm going to change it when I get back home and see what changes. I will let you guys know if it solved my problems. Thanks a lot for the help and info!
  10. GrapeApe
    GrapeApe Road Train Member
    Jan 7, 2013
    2,215
    Thanks Received:
    2,211
    When you seen multiple low current codes (FMI 5), you most likely have a harness issue. The injector harness's have an very high failure rate, which is most likely 1 of your problems with the IVA codes. However, you have more going on there, the other codes do not rely on either of the injector harness's. That's more likely a main harness. You really need to get it hooked up to Cat ET and do some diagnosing.
