Peterbilt air won't build up when I'm idling
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dawn3mckinley, Sep 8, 2011.
  1. Dawn3mckinley
    Dawn3mckinley Bobtail Member
    Sep 7, 2011
    Thanks Received:
    We have a 2004 Peterbilt 379 C15 CAT it won't build up air pressure when it's idling, you have to hold it at 1400 RPM's for it to build up. And once it does build up and you shut the truck off the air pressure don't seem to drop. Put a new compressor on and this didn't fix it. New governor, 2 new main steel braided lines.
    Any ideas??
  2. dave26027
    dave26027 Road Train Member
    Sep 10, 2009
    1,284
    Thanks Received:
    804
    Dallas, Texas
    Air dryer. It's the only thing left after making sure nothing's obstructing the incoming air supply (like a foreign object or a hose with a collapsed inner lining).
    Dawn3mckinley Thanks this.
  3. Dawn3mckinley
    Sep 7, 2011
    Thanks Received:
    I hadn't thought of a collapsed line. That makes sense too. My last resort was spending another $500> on a dryer. But if that is the problem that's fine. Just wanted all other options. Thanks
    dave26027 Thanks this.
  4. aussiejosh
    aussiejosh Road Train Member
    Aug 28, 2009
    4,709
    Thanks Received:
    5,409
    Airlie Beach QLd
    Thats it brother you start at the source and work your way back :biggrin_2558:
  5. bender
    bender Road Train Member
    Jul 20, 2010
    2,105
    Thanks Received:
    1,356
    Don't Kid Yourself
    Check air intake plumbing to compressor for blockage.
    Bypass air dryer for testing (connect the 2 large lines together)
    Disconnect and plug signal line to air dryer (small line from unloader port of air governor) to be sure air from dryer isn't being sent back to unloader valves.
    EverLuc Thanks this.
  6. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,770
    Thanks Received:
    6,210
    What bender said!
  7. Poor boy
    Poor boy Bobtail Member
    Feb 10, 2011
    49
    Thanks Received:
    43
    Kansas
    There is a line running from your airtank to your air governor that should kick in the compressor. I had one of these plug up with moisture and oil from a worn out compressor and do the same thing to my new compressor.
  8. TNPRIDE1066
    TNPRIDE1066 Light Load Member
    Jun 11, 2009
    84
    Thanks Received:
    49
    TRENTON ,GA
    Check the turbo acuator, mine did the exact same thing drove me nuts. Found it and replaced it no more problems
