Peterbilt Power Issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by snidertrucking4, Jan 6, 2018.
  1. snidertrucking4
    snidertrucking4 Bobtail Member
    Jan 6, 2018
    4
    Thanks Received:
    I have a 2002 Peterbilt 379. Truck will start and run with no problem. I have no power to the ACC side of the truck. I have not heat, wipers, power mirror, ect. Anyone have any ideas as to why or where to look. I have checked the fuses under the dash. I am lost and could use some help. Thank you.
  2. GrapeApe
    GrapeApe Road Train Member
    Jan 7, 2013
    2,215
    Thanks Received:
    2,211
    The Main Accessory Relay in the dash is where I'd start. It's on the left side usually above the fuse panel in the key switch area. It is a large 75 amp relay, part # 16-03405. Key accessory power activates it to power up all the accessory fuses.
    bigguns, Oxbow, maggard359 and 2 others Thank this.
  3. ShooterK2
    ShooterK2 Road Train Member
    Dec 14, 2012
    5,533
    Thanks Received:
    89,470
    Oklahoma
    First couple of places I'd look are inside the battery box and behind the ignition switch. Look for wires that have come off or disconnected. Any fuses or relays you find should be checked. Also check where the harness plugs into the ECM and the back side of the fuse box.
    I wish I could point you to a more specific place but this is kinda strange that NOTHING is working. Tells me it's gotta be a major wire or a harness plug or something.
    Oxbow Thanks this.
  4. ShooterK2
    Dec 14, 2012
    5,533
    Thanks Received:
    89,470
    Oklahoma
    Grape Ape knows his business. Check that relay.
    Oxbow and swaan Thank this.
  5. Old Man
    Old Man Road Train Member
    Apr 3, 2009
    4,597
    Thanks Received:
    13,471
    Oklahoma City, OK
    Take out the far left dash panel and the relay is in there, there are 2 in there back to back. Small one closed with the key and energize the big one that power all the acc.
    You can change it, just hard to reach, probably loose a little skin but that is where you problem is
    bigguns, Oxbow and ShooterK2 Thank this.
  6. LA runner
    LA runner Light Load Member
    Aug 1, 2017
    93
    Thanks Received:
    25
    Super reply.....
  7. snidertrucking4
    Jan 6, 2018
    4
    Thanks Received:
    Ok found the big relay. Used a jumper wire and got everything to work but my cab heater
  8. Old Man
    Apr 3, 2009
    4,597
    Thanks Received:
    13,471
    Oklahoma City, OK
    Hope it is a big wire, keep the fire extinguisher handy
    bigguns Thanks this.
  9. snidertrucking4
    Jan 6, 2018
    4
    Thanks Received:
    Yes it was a big wire just used it to test the relay. Got the new relay in and everything seems to work
    GrapeApe Thanks this.
  10. Old Man
    Apr 3, 2009
    4,597
    Thanks Received:
    13,471
    Oklahoma City, OK
    How much skin did you scrape off?
