1996 Peterbilt 378 Speedometer Issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by stewtrk23, Mar 11, 2025.
  1. stewtrk23
    stewtrk23 Bobtail Member
    Mar 11, 2025
    Thanks Received:
    I have a 96 Peterbilt 378. Changed out the engine from a Cummins M11 to a Cummins ISX15. Speedometer keeps going out with a check engine light. Changed the speedometer already. Usually happens when loaded and driving a long distance at a constant speed. Sometimes will come back on when do local work with more shifting. Any advice what it can be?
  2. bjytech
    bjytech Light Load Member
    Nov 9, 2013
    242
    Thanks Received:
    221
    Need to check the speed sensor on the back of the transmission and check to make sure the yolk coming out of the trans is tight, if it's loose that can cause loss of speed signal. after that time to start chasing the wires from the speed sensor up to the ECM. Being a 96 it could have a old 4 wire speed sensor, if so one set of 2 goes to the speedometer and the other set goes to the ECM.
  3. stewtrk23
    Mar 11, 2025
    Thanks Received:
    I checked the speed sensor and yolk looks tight. I’ll check the wires next chance I get. Thank you
