Just got code on a 2012 D13. Code is SPN 4811 FMI 2 Oil psi sensor? Somebady can help with location and part#? Please help! Thanks, Mike.
We don't know your location. Just call the dealer nearest you in the morning, or someone that wrenches on Volvo's. They will tell you what the code is. You probably have to go there and get it replaced. TA's and such don't speak Volvo, they don't have the software.
I changed that sensor. Two weeks ago the light went out no codes and that same code came back. Do you know what it might be. Thanks.
No single codes leading up to this all at once the following codes came up today. SPN 1072 FMI 4 SPN 4811 FMI 2 SPN 4813 FMI 4 SPN 1265 FMI 4 SPN 647 FMI 5 ALL BUT THE LAST one showing faulty wiring harness. Anyway this could be from my ELD that plugs in the OBD2 port? This morning when I hooked the other end up it shorted out.
