Polarity swap normal? and what part is broken
Discussion in 'Ask An Owner Operator' started by skallagrime, Sep 7, 2021.
  1. skallagrime
    skallagrime Road Train Member
    Apr 10, 2012
    3,856
    Thanks Received:
    9,943
    Indiana
    Kw t600 94
    Okay, got a headscratcher here for yall
    When i turn key on, dash warning lights come on like they should, then after a few seconds, engine light goes away, everything else remains.
    This is annoying but fine i guess, pull fuse and add a seperate low air light warning, is what it is.
    what i DO have an issue with may be linked to the cluster stopping proper operation. the signal wires from 5th wheel, air dump etc at key cycle flip polarity depending on if the fuse to warning panel is on or not
    So no fuse/key off power, key on if i hit the air dump signal wire (to cluster) it is negative, when i ADD the fuse, it becomes positive.
    Im guessing this is because the warning cluster wants to turn on the light to make sure it works, then shut itself off after 3 seconds so by simply polarity switching for those few seconds, it can, but its "stuck"? So they never turn off.
    Well, heres my problem with that, i changed to 12v solenoids triggered by relays from switches, so cycling a key would dump air, release 5th wheel lock diff for 3 seconds, and that didnt seem great.
    So question 1, why do it that way? Seems weird to go to swapping polarity for a light
    Question 2, what probably broke resulting in warning cluster constantly stuck?
    How would you set up the wiring if you did fix it so i could have air dump warning light cycle but not have the air actually dump?
  2. Ridgeline
    22,389
    Thanks Received:
    116,330
    94?
    Did you check the grounds at the cluster?
    skallagrime Thanks this.
  3. skallagrime
    Apr 10, 2012
    3,856
    Thanks Received:
    9,943
    Indiana
    And yes, 1994
    Yes and no, at cluster its constantly being powered, no matter what i do if key is on. It is entirely possible that this is linked to my dash lights turning on with key, spent 6 hrs tracing things last night, but fixed 4 problems and this one is persistent, almost like the dash lights have a nick SOMEWHERE to hot, turning em on all the time.
    Left my fancy electric tester at home so only have led red/green test lead atm and can rig up a spare voltmeter i dont trust much at each spot
    Already disconnected dimmer switch from the mix but that didnt do anything
