Potential hazard and CSA points at risk, what should I do??
Discussion in 'Questions From New Drivers' started by Jrivas23, Feb 15, 2015.
  1. Jrivas23
    Jrivas23 Light Load Member
    Jan 6, 2014
    288
    Thanks Received:
    85
    Providence, RI
    Here's my situation.
    Friday afternoon I pull into a fuel island at a Pilot and as am pulling in I hear and feel the truck squealing and steering wheel becomes super hard to turn. I open my hood and confirm my suspicion. Power steering fluid leaking everywhere. Reservoir tank is barely reading any, but it appears to be leaking from the steering box (picture attached)
    I call my company and they advise me to put some ATF fluid on it and to keep monitoring the level and the leak itself until I get routed to a terminal (several hundred miles away) to get the techs there to take a look at the issue.
    I had twenty thousand second thoughts about it, but agreed to keep monitoring it. I buy 5 bottles of fluid and start rolling. My next stop, about 100+ miles away I had to pour about another bottle into the reservoir because I had already leaked out about that ammount.
    I call maintenance and my FM and get the same advice again telling me that going somewhere else would make me sit for days (this even after making clear I don't feel this is safe), maybe weeks waiting for a part (not sure if that would sound like a remote possibility) and got routed home.
    Currently home having tooooo many second thoughts regarding moving this truck monday at all.
    First thing that worries me is if I get pulled in for inspection AM DEFINITELY gonna get fried and CSA points are gonna reflect on me.
    To you seasoned drivers, I ask, what the hell should I do??
  2. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,837
    ga
    If you are going to drive it buy some lucus power steering stop leak or put in motor oil instead of ATF that is thin an will leak out faster.
    EZX1100 Thanks this.
  3. double yellow
    Aug 28, 2011
    5,946
    Thanks Received:
    10,066
    State of Jefferson
    Personally, I wouldn't have a problem driving straight to the terminal, but I wouldn't wait to be "routed in."
  4. Jrivas23
    Jan 6, 2014
    288
    Thanks Received:
    85
    Providence, RI
    If I get pulled over and inspected or targeted at a weight station, what kind of consequences would I be facing though?
    It would still be my license on the line... Would'nt it?
  5. double yellow
    Aug 28, 2011
    5,946
    Thanks Received:
    10,066
    State of Jefferson
    Yes, it would be on your record as a non-moving violation. You might or might not be put out of service -- your pic didn't post...
    Chances of being stopped are slim, inspected slimmer. Write it up on your dvir and get it fixed expediently, but if you refuse to drive in BFE -as is your right- you'll probably be sitting unproductive for days waiting for it to be fixed and you probably won't be on your FM's nice list. Just the way of the world...
    BrenYoda883 Thanks this.
  6. Skate-Board
    Skate-Board Road Train Member
    Aug 9, 2014
    3,801
    Thanks Received:
    3,996
    Merrimack, NH
    Just a note. You don't get CSA points. Only the company does.
  7. DustyRoad
    DustyRoad Road Train Member
    Feb 23, 2011
    1,540
    Thanks Received:
    17,104
    Gulf of Mexico
    Operating a CMV with a Power Steering Violation, the driver is issued a citation with his name on the record, including the company and dot number.
    Power steering violations - 393.209
    6 points Vehicle Violations (Driver Receives Points)
    Level 1 – North American Standard Inspection
    Examination of:
    Driver's License
    Driver's Daily Log
    Driver and Vehicle Inspection Report
    Coupling devices
    Medical card
    Seat belt
    Brakes
    Exhaust system
    Frame
    Fuel system
    Turn signals
    Brake lamps
    Tail lamps
    Headlamps
    Lamps on projecting loads
    Safe loading
    Steering mechanism
    Suspension
    Tires
    Trailer bodies
    Wheels and rims
    Windshield wipers
    Hazmat requirements
    drvrtech77 and MaldonadoVet2 Thank this.
  8. RetiredUSN
    RetiredUSN Medium Load Member
    Jan 9, 2015
    694
    Thanks Received:
    991
    Drive it to the terminal and have it fixed. It's on them.......not you. What would happen if you lost power steering altogether in a bad situation? ..... it would be on you.
  9. Skate-Board
    Aug 9, 2014
    3,801
    Thanks Received:
    3,996
    Merrimack, NH
    Not sure where you pulled that out of. You don't have a clue what CSA points are and who gets them. Only the company, not the driver. This topic is like a broken record in here.
    Here's a challenge. Lets see someone post their CSA points!!! They can't because there aren't any. Only a COMPANY gets CSA points!! GEEZUS!
  10. drvrtech77
    drvrtech77 Road Train Member
    Mar 20, 2010
    14,630
    Thanks Received:
    141,713
    any violations found during insp points are issued to both the driver and the company.
    DustyRoad Thanks this.
