Primary gauge shows no lbs, with no buzzer. Bad gauge?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by thunderjaxx, Jul 31, 2012.
  1. thunderjaxx
    thunderjaxx Bobtail Member
    Jun 6, 2011
    7
    Thanks Received:
    big D
    primary gauge shows no lbs,with no buzzer.Is this just a bad gauge or worse
  2. Houndstooth
    Houndstooth Light Load Member
    Jun 12, 2012
    55
    Thanks Received:
    6
    Phenix City, Al.
    Stop......then apply pressure to the pedal....if your guage that shows how many pounds your applying reads 30 or more pounds, and you check it this way a few times its a bad guage....but I will say its probly not to safe to drive with that particular guage out of order.
  3. not4hire
    not4hire Road Train Member
    May 16, 2012
    7,142
    Thanks Received:
    26,957
    Calgary
    Is the truck running?
  4. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,590
    Thanks Received:
    13,308
    the primary gauge wouldn't stop the truck from functioning. but it would be a oos violation.
    if the truck builds air and can roll. that's all that's needed. a defective gauge is just something that needs to be fixed before a level one happens. :biggrin_25519:
    but yeah, is the truck running.?
  5. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,804
    Thanks Received:
    6,253
    Some trucks have mechanical gauges, some are electrical, some are electronic and some are digital. Some trucks have separate sensors for the low air, some truck dashes are pre programmed to turn on the warning buzzer when the gauge gets down to a certain mark, (electronic and digital). All trucks are also required to have a visual warning light when one system is down. If you aren't getting the audible or visual warning with the one system, buy you do when air is pumped down, chances are it is just a gauge.
    What kind of truck, model, year?
  6. thunderjaxx
    Jun 6, 2011
    7
    Thanks Received:
    big D
    2006 volvo.and yes when i pump the brakes the buzzer will sound off.also when i drain the tanks they all have air.here is what it did today buzzer when off.pressure was up.it shut down.i started it back up and everyting was fine
  7. thunderjaxx
    Jun 6, 2011
    7
    Thanks Received:
    big D
    yes it runs
