Problems with Alley Dock testing
Discussion in 'Questions From New Drivers' started by JSC1, Apr 12, 2010.
  1. JSC1
    JSC1 Bobtail Member
    Apr 12, 2010
    Thanks Received:
    Granville, OH
    I've been trying to pass my driving skills test, but I keep running into problems with the 90 degree Alley Dock. I try to do it the way the instructors want it done, but it keeps coming out wrong. The truck goes in crooked, too far to the right, too far to the left, hit lines, etc.
    I could use some hints on helping to pass it, especially since I have a third retest coming this friday, and I don't know if I'll be ready for it.
    Can anyone give me any pointers on how to pass it?
    TruckGal13 Thanks this.
  2. statikuz
    statikuz Medium Load Member
    Jun 22, 2009
    401
    Thanks Received:
    140
    Reno Nevada
    Well it's hard to explain it accurately but here's how I did it:
    Drive perpendicular to the docking spot as close to the cones as you can.
    As soon as your drive axles meet the second cone turn hard right out away from the dock.
    Keep going for a little bit then come back to the left. (depends on how much room you have at the test).
    Now your tractor will still be perpendicular to the dock spot but your trailer will be pointing back towards it a little.
    Now I would just put it in R without messing with the steering and back slowly to get an idea of how you are lined up (or not lined up). It helps if you can look at your trailer tires and sort of "project" the track they will take as you back up.
    It is pretty tough to explain but you will get it soon enough.
    TruckGal13, LostOne9 and Baack Thank this.
  3. lovesthedrive
    lovesthedrive R.I.P.
    Nov 11, 2008
    15,953
    Thanks Received:
    54,484
    Sorrento Maine
    If your having difficulty with the passing, I suggest you get more practice.
  4. Baack
    Baack Road Train Member
    May 24, 2007
    15,294
    Thanks Received:
    10,174
    Wisconsin
  5. Allow Me.
    May 28, 2009
    10,676
    Thanks Received:
    12,223
    Rancho Mirage, Ca.
    This may sound corny, but it works. I was an instructor and told my students who were having problems backing to rent a U-Haul trailer and practice for hours on end backing into a driveway or parking lot space. The concept is the same, just a smaller vehicle. The ones that did follow my advice got the gist of backing and had no problems passing the test. Good luck.
    simplyred1962 and LostOne9 Thank this.
  6. Freebird135
    Freebird135 Road Train Member
    May 7, 2009
    1,527
    Thanks Received:
    906
    In the air conditioning
    backing a uhaul trailer is nothing at all like backing a semi trailer
  7. Runaway02
    Runaway02 Light Load Member
    Sep 28, 2007
    171
    Thanks Received:
    94
    That was a good idea.:biggrin_25514:
    simplyred1962 Thanks this.
  8. lovesthedrive
    Nov 11, 2008
    15,953
    Thanks Received:
    54,484
    Sorrento Maine
    But the concept of where the trailer will go when you back up is the same. Granted they should be doint it with a goose neck or a 5th wheel trailer.
    simplyred1962 and Runaway02 Thank this.
  9. Swaps
    Swaps Heavy Load Member
    Jan 10, 2010
    757
    Thanks Received:
    361
    Minnesota
    yeah, backing with a 5th Wheel is completely different then backing with a bumper hitch.
  10. Runaway02
    Sep 28, 2007
    171
    Thanks Received:
    94
    But isn't the CONCEPT still the same?Mainly learning to turn the steering wheel in the opposite direction and learning how to track the trailer tires?
