Qcomm help
Discussion in 'Knight' started by Randokuky, Apr 21, 2012.
  1. Randokuky
    Randokuky Light Load Member
    Oct 25, 2011
    134
    Thanks Received:
    54
    Denton, Tx
    For some reason the main display says "driver : unidentified" but I'm the active driver anyone know why?
  2. housecat
    housecat Light Load Member
    Sep 2, 2008
    53
    Thanks Received:
    12
    Flat Rock, MI
    You need to sign in. Hit "view status" arrow down until it says Press '2' to sign on, '3' to sign off and then press the number 2. It will take you to a screen to input your driver id twice, and then ask you for your name
  3. Randokuky
    Oct 25, 2011
    134
    Thanks Received:
    54
    Denton, Tx
    Tried that but when it says type in your id it will only let me use numbers . So I can't put my driver id
  4. mitchtazz
    mitchtazz Road Train Member
    Sep 6, 2009
    1,826
    Thanks Received:
    503
    Lake Wales, Fl
    gotta use your social security number.. you only use your driver ID to log into and out of the Q-Hos.. and something to note, make sure the shop clears out your idle percentage.. and then log in and run, but dont idle.. if you want to idle, log out.. and idle under unidentified.. and it wont limit ya truck.. but if "unidentified" gets too high of a idle percent it'll cut the truck back reguardless.. to keep un identified from getting too high of a percent, when you go to log back in, it will say (**hr**min of uncredited time, assign time to driver Y or N). Only say yes when you know your idle percent is well below ten percent.. when you say yes, it'll give all of that idle time to your profile and you'll see your idle percent jump, but it's ok as long as you keep driving and not idling, cause every week or so it will automatically reset all of the numbers, fuel burnt, miles ran, mpg, idle, over idle, over speed.. all of that will reset and start over.
  5. mitrucker
    mitrucker Road Train Member
    Dec 15, 2010
    5,147
    Thanks Received:
    8,827
    Lapeer, MI
    My QC says unidentified too. It doesn't mess with my logs, or my governor for that matter, so I quit worrying about it. It said "rob" when I got the truck so I logged him out.
  6. pattyj
    pattyj Road Train Member
    Jul 19, 2008
    22,474
    Thanks Received:
    20,138
    Sioux City,ia
    Its been so long since I used the qualcomm I think I forgot how.Some ppl pronounce the qualcomm as quailcomm,isn't the quail a bird,lol.
  7. mitrucker
    Dec 15, 2010
    5,147
    Thanks Received:
    8,827
    Lapeer, MI
    Sure is....I still laugh every time I hear that!!!!
  8. mitchtazz
    Sep 6, 2009
    1,826
    Thanks Received:
    503
    Lake Wales, Fl
    yeah, Quality Communications, and dont see skit quality about it.. doesn't really work all that well up north, and cuts in and out when it's raining hard.
  9. mitrucker
    Dec 15, 2010
    5,147
    Thanks Received:
    8,827
    Lapeer, MI
    Tried it that way....that works. Wound up leaving it as "unidentified" for now though. Will change it at a later time.
