Qestions about dump trucks and what CDL Class
Discussion in 'Questions From New Drivers' started by gambit1983, Jul 12, 2016.
  1. gambit1983
    gambit1983 Bobtail Member
    Jun 11, 2016
    11
    Thanks Received:
    I see there is something like 9 different types of Dump trucks. I'm guessing the bigger ones require CDL A and the smaller ones require CDL B. Can someone clarify this for me? I'm looking to get a CDL B and want to drive a dump truck but, i want to know what i'm getting into.
  2. David_Simpson
    David_Simpson Medium Load Member
    Feb 23, 2016
    650
    Thanks Received:
    637
    best to get an A CDL. covers it all. then someday, you may get asked to haul a load over several states for the dump company, that may also have either dry vans, flatbeds, or reefers. why limit yourself? the cost may be an issue, but to add the A later on will require the combo written test, and a driving test. may very well cost more later to upgrade.
    FinkPloyd Thanks this.
  3. Mikesee
    Mikesee Light Load Member
    Oct 25, 2014
    90
    Thanks Received:
    51
    You may want to consider getting a class A as they may ask you to hook up to a trailer. That's when you need a class A with a dump truck.
  4. Osiris
    Osiris Light Load Member
    Dec 3, 2015
    154
    Thanks Received:
    124
    Philly
    Most should be B unless you're pulling or towing other equipment.
  5. TripleSix
    18,459
    Thanks Received:
    129,307
    1. Asphalt is work. You will have to work keep that stuff from building up in the bed.
    2. Spreading gravel is dangerous if you live in hill country. Especially when you're trying to go down the driveway you just spread. The truck will start to bounce and skip downhill.
    3. The pay is at best, "okay".
    4. Seasonal work. Winter time is D.E.A.D
    WitchingHour and johndeere4020 Thank this.
  6. Giuseppe Ventolucci
    Giuseppe Ventolucci Medium Load Member
    Nov 29, 2015
    611
    Thanks Received:
    616
  7. okiedokie
    okiedokie Road Train Member
    Jun 13, 2011
    12,168
    Thanks Received:
    90,338
    PNWET
    There 3 kinds of dump trucks. End dumps,side dumps and belly dumps. The rest are a variation of these. It takes some skills to run these kinds of trucks. Your not driving down the Interstate pulling a van.
  8. WitchingHour
    WitchingHour Road Train Member
    Apr 1, 2011
    3,424
    Thanks Received:
    2,143
    Broomfield, CO
    License classification in this county is so screwy. If I run a 13,000 GVW pickup with a 14,000 GVW trailer, for a GW of 27,000 lbs., then I'd need a Class A CDL, but I could run a 26,000 GVW truck (like an F650) with a 10,000 GVW trailer for a GCW of 36,000 lbs., and not require a CDL at all. IMO, they had the classification system a lot better organized in South Africa.
    As for the OP's question, I concur... just get the Class A. Dump truck driving really isn't an industry all its own.. it's something which is a part of many industries, and can be very varied. Sure, you can run a straight dump truck with a Class B, but in a lot of industries involving dump trucks, you may have to pull 10,001+ GVW tag trailers, transfer trailers, etc., and will need a Class A for that. Then there's the matter of semi dump trailer combinations, which will also require a Class A.
    Not to mention one of the first things they'll tell you in school is to "leave yourself an out". Which, in their context, pertains to driving, but it's excellent advice when applied to the grand scheme of things, as well. You might not like driving dump trucks. You might get sick of seasonal layoffs. So if you start looking for greener pastures, that Class A will leave you a lot more options than a Class B would.
    okiedokie Thanks this.
  9. foreverlearning
    foreverlearning Bobtail Member
    Nov 10, 2013
    46
    Thanks Received:
    48
    CT
    In CT any vehicle with a GCWR over 26,000 or any vehicle pulling a trailer rated for over 10,000 requires a CDL -A. Even if the truck and trailer are empty.
    I used to drive for an asphalt company. Our drivers were expected to transport machinery to the job site, run machinery, help with demolition, go get asphalt, and many times help with laying down new asphalt. Pay was decent. New guys started at $15 an hour and usually were making $20 an hour after a couple years. I actually started there as a laborer and moved into driving. Did 6 years with that company. Expect to work 14 hours a day every day the plant is open with start times from 3 - 6 am
  10. gambit1983
    Jun 11, 2016
    11
    Thanks Received:
    so was the plant mainly just closed during bad weather and the winter?
