Question about securing coated gas pipe
Discussion in 'Questions From New Drivers' started by marinevet93, Mar 2, 2011.
  1. marinevet93
    marinevet93 Bobtail Member
    Mar 2, 2011
    12
    Thanks Received:
    Va
    Hey all,
    I'll be hauling my first load of coated gas pipe next week and would like some advice on how to adequately secure it. I've actually taken a hiatus from trucking for a few years and have decided to get back on the road and this will be my first haul for a local company. Haven't actually pulled a flatbed since '94! And even then, it was just drop and hook. Any advice would be greatly appreciated....and pics would be awesome!
    Thanks in advance!
  2. notarps4me
    notarps4me Road Train Member
    Jan 1, 2007
    10,311
    Thanks Received:
    5,253
    NASA HQ
    Belly wrap the front and back of each bundle. Gut strap and if you have room on the deck you can build a bulk head.
    Ranger_309 Thanks this.
  3. notarps4me
    Jan 1, 2007
    10,311
    Thanks Received:
    5,253
    NASA HQ
    This is a belly wrap. You can also see the bulk head. This was a 2-stopper. My last stop only had one piece, but you can see what I am talking about.[​IMG] [​IMG]
    This load only had one bundle, but again you can see the belly wrap and the bulk head. [​IMG][​IMG]
    This was a full load. You can see the gut straps and smoke tarp.[​IMG]
  4. marinevet93
    Mar 2, 2011
    12
    Thanks Received:
    Va
    Thanks for the response and pics. This load will be about +/-25 ton of 6" steel pipe. Excuse my ignorance but I'm not familiar with some of these terms, but it looks like a "belly wrap" is when the strap is wrapped completely around the pipe and a "gut wrap" is just across the top of the pipe, correct?
    When hauling a full load like I will, would I belly wrap each row of pipe or gut wrap each row....or both?
  5. notarps4me
    Jan 1, 2007
    10,311
    Thanks Received:
    5,253
    NASA HQ
    Your welcome! That is why I posted the small loads. You can see what the straps look like. The belly wrap is correct. I like to use chains on steel if possible. Some pipe has to be straps. If it is in bundles I try to belly wrap each bundle or layer. Different pipe is secured differently. Pipe stakes are also good to use. The gut strap will be a couple straps tossed over and then more pipe put on top. After everything is on you will strap over the top of all of it.
    Some times you can't get a belly wrap. I try to at least do the first layer front and back of each bundle. Pipe can be dangerous. Even when you are unstrapping it. It can roll off and kill the driver or a fork truck might try to pick up a bundle on the other side and knock it off while you are still loosening straps. Just be careful and ask other drivers or the shipper about securement. Sometimes they can help.
  6. marinevet93
    Mar 2, 2011
    12
    Thanks Received:
    Va
    Thanks man. Yeah, this will definitely have to be straps since it is coated pipe. So basically the best thing to do would be belly wrap each row, if possible, of pipe with 2 straps each and then gut wrap the top row every 8-10' the entire length of the pipe?
  7. Pmracing
    Pmracing Road Train Member
    Jan 28, 2011
    6,354
    Thanks Received:
    3,178
    Arlington Heights, IL
    I know "securement" is not an endorsement by itself, but shouldn't there be some sort of formal training, before they send out any random driver with all that responsibility?
    I mean, it is 25 tons? That is more than dropping a bowling ball on your toes...
    Mikeeee
  8. marinevet93
    Mar 2, 2011
    12
    Thanks Received:
    Va
  9. notarps4me
    Jan 1, 2007
    10,311
    Thanks Received:
    5,253
    NASA HQ
    By that diagram I would have belly strapped the very front and back of that load; plus built a bulk head in front of it. Other than that it looked good.
  10. bs64507
    bs64507 Light Load Member
    Jan 25, 2009
    279
    Thanks Received:
    110
    St Joseph, MO.
    Most companies provide training, but sometimes you just forget.
