Question about shifting: Is my instuctor correct?
Discussion in 'Questions From New Drivers' started by tarheelmike, Oct 30, 2012.
  1. tarheelmike
    tarheelmike Bobtail Member
    Jul 5, 2012
    6
    Thanks Received:
    I am about 2 weeks away from graduating CDL school and my question concerns my instructors' directions regarding double clutching. He wants us to press the clutch ALL the way to the floor during double clutching. My problem is that his preferred truck drops rpm's very quickly. I feel that by pressing the clutch all the way to the floor (and activating the clutch brake) this is causing me to lose time changing gears while trying to keep my engine and road speed up. Some other guys in my class are having the same problem, so it's not just me. Any advice/opinions on this subject? Thanks.
  2. ghf
    ghf Bobtail Member
    Oct 2, 2012
    18
    Thanks Received:
    15
    Seattle, WA
    Pressing the clutch all the way to the floor and engaging the clutch brake while in motion, will destroy the clutch brake; and will not help in shifting. If using the clutch to shift, either up or down, all you have to do is engage the clutch just enough to break the torque; usually this means just pressing the clutch an inch or two.
    MNdriver, tl385 and volvodriver01 Thank this.
  3. rbrtwbstr
    rbrtwbstr Road Train Member
    Jul 11, 2012
    3,374
    Thanks Received:
    7,785
    in the bush somewhere
    If he has you pushing the clutch all the way to the floor, he wont have a clutch brake for long. Just push it far enough to get outta gear easily, and just far enough to get it back in gear easily. How long has the instructor been driving???
    Pmracing Thanks this.
  4. Balakov100
    Balakov100 Road Train Member
    May 10, 2012
    3,937
    Thanks Received:
    2,637
    Temple, TX
    only time you push the clutch to floor is when stopped.
  5. chompi
    chompi Road Train Member
    Jun 21, 2008
    5,653
    Thanks Received:
    3,485
    Deland, FL
    The only advantage to pushing the clutch all the way to the floor is to engage the clutch brake which is only necessary when coming to a stop or starting from a dead stop. Technically you don't have to use the clutch at all when shifting. It is called "floating" and is how most experienced drivers shift. However you are just learning and need to learn how to do it the textbook way. I guess if this is the guy doing the training and testing then you better do it his way.
    If you run the rpm's up a little higher it will give you a little more time to shift. If they drop to quickly for you to get it in gear then just tap the fuel pedal to bring the rpm's back up a bit and drop er in gear.
    DrtyDiesel Thanks this.
  6. Balakov100
    May 10, 2012
    3,937
    Thanks Received:
    2,637
    Temple, TX
    It is possible that the Clutch Brake doesn't work rightto begin with. Some of those Trucks are pretty worn out.
  7. tarheelmike
    Jul 5, 2012
    6
    Thanks Received:
    That's what I'm thinking but he insists we do it his way. BTW, when he is at the wheel he only presses it in about 2-3 inches and then wonders why we can't shift as smoothly as he does!
  8. tarheelmike
    Jul 5, 2012
    6
    Thanks Received:
    GHF, that's what I'm thinking but he insists we do it his way. BTW, when he's at the wheel he only presses the clutch 2-3 inches and the wonders why we can't shift as smoothly as he does!
  9. FozzyNOK
    FozzyNOK Road Train Member
    Jul 18, 2007
    2,459
    Thanks Received:
    3,786
    Oklahomistan
    Treat the clutch like a hot iron.. tap - neutral - tap gear..
  10. ShootThis
    ShootThis Medium Load Member
    Jun 20, 2012
    606
    Thanks Received:
    779
    Wondering Where I AM Again???
    Way it sounds he graduated from the class before the OP.
