Questions DMV CT Hazmat and D/T?
Discussion in 'Questions From New Drivers' started by Papa0, Aug 9, 2018.
  1. Papa0
    Papa0 Bobtail Member
    Aug 2, 2018
    19
    Thanks Received:
    10
    New Haven, Connecticut
    Hello everybody, I would like to know if right here someone know a place where study the REAL questions for Hazmat And Doubles and Tripples, I failed on both this morning because the questions I studied wasn't the same I saw in DMV, I studied on CDL Prep and DMV Genius and I always pass 100% the test on the applications, I live en Connecticut someone can help me with a good thing about that I don't know
    Thank you!
  2. Brandt
    Brandt Road Train Member
    Sep 17, 2012
    4,592
    Thanks Received:
    6,305
    Go to the DMV and get the CDL book. In my state the test is all on computers. I'm guessing every state is. We can skip a question not sure about and answer it at the end or best guess. Once we got 80% correct we get passed test.
    It a lot to read because they put in trick questions
  3. kemosabi49
    Jan 13, 2013
    10,901
    Thanks Received:
    47,292
    SW Arkansas
    Did you do the practice tests here on TTR?
  4. Omega7777
    Omega7777 Medium Load Member
    May 21, 2018
    392
    Thanks Received:
    414
    test machines are programmed to randomize certain number of questions. the best way is continue to retake the test until you know enough questions to pass ;) . if you choose the wrong answer, do take your time to remember the question and the answer, dont just say **** and skip to the next
  5. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,141
    White County, Arkansas
    You cannot memorize a study test guide and then expect to take on a computer that changes or shuffles words around on the test.
    You have to have the actual CDL Hazmat manual and so forth in your reading material and study this stuff.
    Then consider carefully each question that is put before you.
    There will be times out here in the real world lives will depend on what you put on the truck, or not.
    Brickwall Thanks this.
