Ramps for Flatbedding Applications
Discussion in 'Flatbed Trucking Forum' started by jldilley, Mar 5, 2015.
  1. jldilley
    jldilley Medium Load Member
    Oct 13, 2013
    485
    Thanks Received:
    406
    Indianapolis, In
    Hello fellow flatbedders!! Before I ask my question, I just wanted to give a big thanks to all of you. As some of you know, about this time last year I went and took my securement course in Jacksonville and started flatbedding after 8 years of pulling vans and reefers. After a very interesting, and sometimes trying, first year, I can honestly say I love open deck freight! And the open deck community has been incredibly helpful and encouraging. Once again, thanks to all of you.
    Now for my question! How many of you flatbedders find it useful to keep ramps with your equipment? I see stepdecks carrying them and using them quite a bit, and today I saw an advertisement showing a flatbed trailer using ramps to load a vehicle. However, I don't recall ever seeing this in person. At very least, it seems much more rare than stepdecks utilizing them.
    As always, your comments and insights into the subject matter are appreciated. :biggrin_25515:
  2. barroll
    barroll Road Train Member
    Nov 23, 2010
    1,096
    Thanks Received:
    544
    Southwest Michigan
    I could never justify the expense. A lot of things that need to be ramp loaded are taller than 8'6". Most of the things that aren't can by loaded by a rollback for $75 or less. I've improvised before (don't try this unless you're at home, like I was).
    In the last 3 years I've needed a rollback to load me about 8 times, and 3 of those came out of my own pocket. The rest can be built into the rate. That comes up WAAAY shy of the $3000+ price tags I've seen on reliable ramps.
  3. Prom Night Dumpster Baby
    Prom Night Dumpster Baby Medium Load Member
    Jan 12, 2012
    646
    Thanks Received:
    473
    Bug Tussle, TN
    Flats are too tall for reasonable ramps. Shipper or consignee can arrange unloading.
  4. Hurst
    Hurst Registered Member
    Aug 24, 2011
    6,618
    Thanks Received:
    12,266
    Tampa, Fl
    Ramps are best suited for a step.
    For me,.. the cost could be recouped with just 1 or 2 loads.
    I use my ramps at least twice a month. Sometimes twice in a week. I really loath having to use them. But when you can negotiate a better rate because the load needs ramps,.. then I can justify the cost.
    For example. Picked up a load today. Broker originally wanted to pay $3200 for a going just over 2000 miles. I said no way. It needed ramps so I said I wanted $5000. We couldnt agree so the conversation ended. He called me back and asked if I would do it for $3850. I said no,.. $5000. Again,.. the conversation ended. My wife called me. My brother is in the hospital, I need to get a few things done on my truck. The load would get me home from Denver. An hour later the broker calls and says he can do $4000,.. and that was his cap. He sounded so desperate. Young guy. I really wanted to stick to my guns,.. but I caved in for $4000. Its a light load, barely 16000 lbs. A limousine party bus.
    Seems no one else in the area with a step had ramps. I was 10 miles from the PU. So no dead head,.. got out of Denver for $2 mi and heading home to Fla.
    It was this load or sitting around waiting for someone in Denver willing to pay more than $1.60.
    So the ramps have served their purpose. I still loath using them,.. LOL
    Hurst
    jldilley, Lone Bear, celery425 and 2 others Thank this.
  5. dannythetrucker
    dannythetrucker Road Train Member
    May 26, 2011
    2,856
    Thanks Received:
    4,032
    everywhere, man
    If you look at the picture in Hurst's post above you will see there is actually 4 - 8' ramps with 2 stands which connect the ramps making them 16'. The stands are height adjustable.
    You could get 6 ramps and 4 stands for a flatbed. This would allow you 24' ramps and keep the angle down. I wouldn't recommend it though, the market is pretty saturated now with stepdecks with ramps. Maybe if you had a customer with use of a flatbed set up that way.
  6. Hurst
    Aug 24, 2011
    6,618
    Thanks Received:
    12,266
    Tampa, Fl
    Yeah I think there is another 8 - 10 inches of adjustment I could raise the ramps. I've only raised the stand above the 2nd hole once in order to load 2 Corvette so they wouldnt bottom out at the deck. I had to use boards at the bottom to keep the nose from rubbing. There are 4 pin setting in the stands that I have. I drop it into the first when storing them under the deck. Then raise to the 2nd slot to keep the ramps even from the lower deck to the ground.
    I dont see where they would be that useful with a regular flat. Most loads I do that need ramps are generally above 10' tall, so they would not work on a regular flat. When I ran flat and did loads with wheel machinery there was always a loading dock. Or if not,.. then like Barroll said,.. for $50 - $80,.. you can get a roll back to come put it on your bed.
    4 stands and 8 ramps!? I cringe at the thought of having to put all that together and then putting it all away. Just get a step.
    Hurst
  7. tommymonza
    tommymonza Road Train Member
    Sep 10, 2013
    4,519
    Thanks Received:
    12,849
    S.W. Florida
    Hurst
    You loaded that Bus with the ramps setup as they are in the pics without the bus bottoming out?
  8. spyder7723
    spyder7723 Road Train Member
    Mar 31, 2013
    15,470
    Thanks Received:
    25,061
    sarasota, fl
    And for what those ramps would cost, thou could hire a rollback a hundred times and still come out cheaper. Ramps work financially for a step especially when did ramps double as load leveled. Not for a flat.
    Hurst, you did good. 2 bucks tho the truck out of Denver is phenomenal.
    Hurst and dannythetrucker Thank this.
  9. dannythetrucker
    May 26, 2011
    2,856
    Thanks Received:
    4,032
    everywhere, man
    I agree, I don't think it's practical for most flatbeds to carry ramps. I was just pointing out that it can be done. I could see someone with a customer wanting to haul some mining vehicles or something requiring ramp delivery. He might prefer to do them with a flat to keep his options open for steel or things that don't work well on a step. hypothetically
  10. Hurst
    Aug 24, 2011
    6,618
    Thanks Received:
    12,266
    Tampa, Fl
    Yes,.. exactly as you see it. Is how I drove it up on my bed. I stopped to make sure it was not going to bottom out. Had about 4 inches to spare.
    Same set up but with the stands raised in the middle is how I loaded two 2002 Z06 Coervettes. They were low. They would not go on with how the stands are in this pic.
    Edit:
    Stopping by the house before I unload to pick up my wife. I'll get her to snap some pics to show the clearance when unloading.
    Hurst
    SMTatham Thanks this.
