Resistor tricks
Discussion in 'Peterbilt Forum' started by Billystex, Nov 1, 2012.
  1. Billystex
    Billystex Bobtail Member
    Nov 1, 2012
    Thanks Received:
    Can anyone help me with the resistor tricks for the c15 was told would help with throttle response and power
  2. FozzyNOK
    FozzyNOK Road Train Member
    Jul 18, 2007
    2,460
    Thanks Received:
    3,789
    Oklahomistan
    I really wouldn't recommend screwing around with the electronics on these things..
  3. bubbanbrenda
    bubbanbrenda Road Train Member
    Feb 27, 2011
    1,388
    Thanks Received:
    650
    Middletown,Oh.
    150 ohm resistor on the fuel temp sensor plug, DO NOT plug the sensor back in, the resistor replaces the sensor. Don't play with the boost sensor, all that does is make tons of smoke and soot up your oil.
  4. kat man
    kat man Light Load Member
    Nov 29, 2009
    234
    Thanks Received:
    195
    orleans in
    Resistor trick is good for .2 mpg, drive easy,not like some company drivers.
  5. Superhauler
    Superhauler TEACHER OF MEN
    Jan 30, 2010
    12,209
    Thanks Received:
    100,730
    keep stroking.
    150 ohm 1/2 watt resistor fools the ecm into thinking the fuel temp is 167 deg. gains are noticable at first them diminish as fuel heats up in tank through the day. but worth doing.
