SA Right PMV Common Circuit Fault?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gomez210, Sep 29, 2015.
  1. Gomez210
    Gomez210 Bobtail Member
    Aug 31, 2015
    7
    Thanks Received:
    TX
    Hello all! I posted this in Peterbilt specifically but saw you can post in the general forum.
    I unfortunately have a fault coming out on my 2010 Pete 389 stating: SA Right PMV Common Circuit. It came up while idling an hour ago. It has a 485hp cummins in it with about 480K miles.
    Has anyone on here ran into this before? If so, how did you or your mechanic spearhead this issue?
    -Gomez
  2. Straight Stacks
    Straight Stacks Paper Cha$er
    Jul 18, 2015
    2,930
    Thanks Received:
    20,768
    Alabama Gulf Coast
    Do you have Bendix Stabilty Control System?
  3. Gomez210
    Aug 31, 2015
    7
    Thanks Received:
    TX
    I do not have the Bendix Stability Control System
  4. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,804
    Thanks Received:
    6,253
    Just a guess, but I am going with "steer axle right side pulse width modulated". Usually the ABS modulator valve is what they are referring to when it comes to pulse width modulated. Common circuit is like the ground circuit return to the ABS ECU. Valve or wiring problem.
    Gomez210 Thanks this.
  5. Gomez210
    Aug 31, 2015
    7
    Thanks Received:
    TX
    Will start with cleaning up the common circuit and go from there. Thank you for that.
