Sabotage at Swift?
Discussion in 'Swift' started by Palazon, Mar 20, 2009.
  1. Palazon
    Palazon Road Train Member
    Feb 5, 2009
    1,430
    Thanks Received:
    912
    Tacoma, WA
    Just curious: Has anyone ever had their truck sabotaged? Yesterday I found a straight nail in my sidewall on the drives. It was near the rim, so doubt it was random debris.
    I've heard rumors of other drivers pulling tandem pins or 5th wheel releases, but always 3rd or 4th hand. Is this just something I'll have to expect working for Swift?
    Thank god I was trained to pretrip every time! I even do a quick walk-around after a bathroom break.
  2. doubledragon5
    doubledragon5 Road Train Member
    Jun 8, 2008
    2,935
    Thanks Received:
    4,088
    Lewisville TX
    I never had any problems while with Swift (1yr). Usually it is from a disgruntle employee or one who just hates them..
  3. Wiseguywireless
    Wiseguywireless Road Train Member
    Dec 21, 2007
    1,693
    Thanks Received:
    801
    Petoskey, MI
    Pay extra caution while in the swift yards, Most other company drivers will leave your truck alone.
  4. Flyin Trucker
    Flyin Trucker Bobtail Member
    Aug 11, 2008
    35
    Thanks Received:
    9
    Houston, Texas
    Seems to me that that ought to be a Federal Crime, maybe a felony. Anyone know if it is ??
  5. Truckersmooth
    Truckersmooth Light Load Member
    Aug 24, 2011
    103
    Thanks Received:
    22
    Denver, CO
    purposely trying to cause a blow out on a tractor trailer should be a felony as if the truck were to crash resulting, it could kill many! Good job catching it! This is why the pretrips, post trips and just general random checks are always good
    mtnMoma and Smaggs Thank this.
  6. Truckersmooth
    Aug 24, 2011
    103
    Thanks Received:
    22
    Denver, CO
    Oh and I might also add.. this probably has nothing to do with swift but probably something that could happen no matter where you are.
    THBatMan8 Thanks this.
  7. ECU51
    ECU51 Heavy Load Member
    Jan 31, 2011
    728
    Thanks Received:
    3,565
    East Carolina,where else would I be
    I have over the years seen many a tire fail going down the road,and the resulting damage and carnage that happens when this occurs,,,
    So i ask you,,Really? If you have seen just ONE tire blow would you actually pound a nail into a sidewall???
    You must have undoubtly run over something and you just dont relize it or remember it
  8. AZS
    AZS Honk if anything falls off
    Sep 30, 2010
    2,912
    Thanks Received:
    1,303
    PHX, AZ
    This thread is old but that said I always check my fifth wheel release handle after any amount of time away from the truck.
    fr8monkey Thanks this.
  9. neal79
    neal79 Medium Load Member
    Feb 9, 2011
    368
    Thanks Received:
    212
    Chicago,IL
    Only problem I have ever had is I had a spare tire stolen once. I do check that 5th wheel though before I get rolling, might just be CB bs, but don't check it and drop a trailer and its defenatly a preventable.
  10. capthook
    capthook Light Load Member
    Jul 16, 2010
    182
    Thanks Received:
    102
    NC
    Well....
    I had 2 times where shiny/new threaded screws were in my drives. (At odd angles)
    Seemed to me someone was going around with a portable drill
    and putting them in... but who knows. Seemed odd.
    However, several (3) times I have had my pigtail pulled.
    A 'dirty trick' that is a little less harmful
    and easy to catch on a walkaround.
    If away from the truck, even after fueling and
    going in for food, check tires/pigtail/5th wheel!
