SCR clogged muffler
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Edio, Mar 16, 2013.
  1. Edio
    Edio Bobtail Member
    Mar 16, 2013
    Thanks Received:
    There are several reports about failures with SCR mufflers.
    But have someone an ideia about how many miles/km you need to clog a SCR muffler with bad DEF?
    How you can see if a muffler is clogged?
    It seems you need cut it.
    In general,the mufflers from CUMMIS are getting a good service life?
    Thanks
    Edio.
  2. Pablo-UA
    Pablo-UA Road Train Member
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    really there are two ways to make DEF.
    To use distiled water and to use demineralized water. Demeniralized water makes deposits. So you have to remove SCR converter and clean it mechnically ore replace.
    It is not all. SCR converter may be combined with DPF and with DOC (Diesel oxydant catalist). So to clean all this stuff we use solvents.
    SCR w/o DPF is Euro-5 Stage 1 (2006), but now we have to use more complicated exaust aftertreatment.
    IGOR-UA and scottied67 Thank this.
  3. Edio
    Edio Bobtail Member
    Mar 16, 2013
    Thanks Received:
    Thank you Pablo.
    Have you heard about a SCR cleaner (a kind of liquid) that is used during the regeneration?
    It claims that the deposits will be burned with help of this aditive.
    Any experience with them,it will not damage the "ceramic"?
    Edio.
  4. Pablo-UA
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    may work, may not.... it is like calgon to use in your wash mashine
