Scraping/Grinding sound after 4th gear?
Discussion in 'Questions From New Drivers' started by Lightning01, May 15, 2020.
  1. Lightning01
    Lightning01 Bobtail Member
    Mar 7, 2020
    26
    Thanks Received:
    29
    I drive a 1999 Mack E7-457 8 speed manual (Eaton fuller). So pretty much, it’s an 8 speed, so in order to go to 5th gear, I would have to flick the range selector up before changing gears. Now, this sound only happens, of course, when driving. And it is the only gear that makes this noise. And also, only when up shifting it will make this noise. I’m guessing it could be a faulty range selector. There’s times where I’ll take out the gear from 4th and the “clicking” set sound of the range selector will delay.
    So for an easier understanding, it happens like this
    1. 1st gear 2nd 3rd
    2.4th
    3. Range selector up
    4. Take out gear
    5. Scraping/Grinding sound
    6. Range selector makes the “set clicking” sound
    7. 5th gear
    I’m a total noob at this so any info will be appreciated, thank you
    truckdriver31 Thanks this.
  2. truckdriver31
    Sep 18, 2013
    6,998
    Thanks Received:
    8,358
    maybe a trans job
  3. Powder Joints
    Sep 25, 2007
    7,898
    Thanks Received:
    8,201
    Rosamond, SoCal
    sounds like a 2 speed rear end more than a tranny.
  4. trucker2121
    trucker2121 Light Load Member
    Apr 29, 2013
    89
    Thanks Received:
    49
    Sounds like it giving u a breakdown hint. i'd act on it before it cost you more money on the side of the road. 1999 is a 21 year old truck keep that in mnd. Might need an upgrade before you start pour alot of money in repairs fix. then a new problem a few weeks later. might need an upgrade while used truck prices are fallen.
  5. bavarian
    bavarian Heavy Load Member
    Feb 13, 2014
    730
    Thanks Received:
    785
    Winnipeg
    That sounds quite normal to me. My 13 speed does the same. Just don't pre-select as long as you in 4th.
    My old tranny did it and the rebuilt one now as well. No difference.
  6. SmallPackage
    Dec 20, 2019
    5,665
    Thanks Received:
    18,098
    Marion Texas
    Try selecting the range after you go into neutral and see what it does. This may not be the “correct” way to shift that trans but it will help you troubleshoot whats wrong with it. See if it is quieter/smoother or not or if it even works at all that way but it will help figure out the problem.
  7. AModelCat
    29,390
    Thanks Received:
    161,299
    Sounds like a range synchro on its way out.
    lester, Lightning01 and jamespmack Thank this.
  8. jamespmack
    20,033
    Thanks Received:
    216,319
    Skipped over most all the bull sheet.
    @amodel is correct. Hi/lo synchro.
    Lightning01 and blairandgretchen Thank this.
  9. Lightning01
    Mar 7, 2020
    26
    Thanks Received:
    29
    Again I’m a noob, would I have to replace the transmission or is that something apart?
    jamespmack Thanks this.
  10. Lightning01
    Mar 7, 2020
    26
    Thanks Received:
    29
