Sdp to 6nz help! No jakes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kswapp13, May 19, 2022.
  1. Kswapp13
    Kswapp13 Bobtail Member
    May 11, 2022
    8
    Thanks Received:
    I have a 2008 kenworth multiplex dash swapped the sdp out for a 6nz used the sdp truck side wiring harness on the 6nz, everything works as it should except no jakes, also will say the truck is an automatic any help is appreciated greatly
  2. kranky1
    kranky1 Road Train Member
    Sep 16, 2015
    2,253
    Thanks Received:
    8,854
    Ontario, Canada
    Never tried it with a Cat. I know a Cummins swap that went sideways like that though. Their problem was the multiplex truck and engine run all the control for the Jake and Cruise on 1 wire and the CM870 didn’t like that. Sounds like you may be against something similar
