Self Defense in Dangerous Areas
Discussion in 'Questions From New Drivers' started by wd40, Jan 3, 2014.
Thread Status:
Not open for further replies.
  1. wd40
    wd40 Light Load Member
    Nov 8, 2013
    241
    Thanks Received:
    116
    I know this hyas been posted before, but after a few attempts I couldn't find it. I'm concerned about being able to have some type of weapon for a few rough areas. I'm trying not to cary a gun, the company doesn't allow them. One guy talked about a piece of heavy guage wire... could someone explain this in more detail (Thickness and length). They said it looks better in court. Does anyone have any other good ideas?
  2. Fester69
    Fester69 Light Load Member
    Oct 19, 2012
    208
    Thanks Received:
    110
    Omaha, NE
    I got a big framing hammer for bumping tires. Bet it would feel below average upside someones head.
    Pmracing Thanks this.
  3. gokiddogo
    gokiddogo Road Train Member
    Mar 5, 2012
    8,786
    Thanks Received:
    14,768
    Ontario Canada
    You will learn what areas you might not want to get out of the truck at night, and other places where you could likely leave your doors unlocked and the keys in the ignition without any problems. The best idea is to park in places you are much less likely to need some type of weapon. The being said, I do carry a regular size hammer beside my seat. I have to knock the snow and ice off in the winter time, also check tires with it ........
    wd40 and Cetane+ Thank this.
  4. wore out
    wore out Numbered Classic
    Jun 5, 2013
    15,845
    Thanks Received:
    191,670
    CHASIN THE DEVIL'S HERD
    A hand made leather quirt like you use on a horse works wonders. Has a loop on it that goes around your wrist and the leather poppers keep you put of arms length. Mine was hand made by a vaquero that took a lot of pride in his work and must have ridden a bigger horse than most. I have been to a few rough areas thou and never had any trouble really. And something to think about is the criminal is not bound by rules he isn't willing to break. It sucks being under equipped for any job so to speak.
    Cetane+ and wd40 Thank this.
  5. Dinomite
    Dinomite Road Train Member
    Sep 6, 2012
    4,092
    Thanks Received:
    4,308
    Looking 4 Rocks
    Nobody bother's broke truck drivers. They see the name on your truck and think you might mug them. You name it I been their and never had a problem, but that's probably because I know how to walk, and drool on myself like the other kids who use to ride the short bus. If it comes to it. Throw some blows and if you get your butt kicked. You have a good story to tell at the truck stop counter. Woop woop truck it up.
    Skydivedavec and n3ss Thank this.
  6. RedForeman
    RedForeman Momentum Conservationist
    Jan 30, 2011
    4,875
    Thanks Received:
    22,138
    Like the stuff used for commercial electric service lines - 4/0 ga and the like. It would be like a plastic coated metal bat. I would think beating someone with that wouldn't be much different in the eyes of the law than if you used a Louisville Slugger or a golf club instead.
    +1 on the hammer plan. I keep this roofing model closer than the toolbox if I'm overnighting in a sketchy area. Hard knocks in the front, party on the back. Definitely got some looks walking back with this to pound tandem pins on the trailer I recently got rid of.
    Skydivedavec, wd40 and Cetane+ Thank this.
  7. realsupatrucka
    realsupatrucka Road Train Member
    Sep 25, 2013
    2,072
    Thanks Received:
    513
    houston tx
    Get a razor blade and a breaker bar
  8. Chewy352
    Chewy352 Road Train Member
    Dec 17, 2013
    1,797
    Thanks Received:
    11,619
    Enid, OK
    3D or bigger maglite. You gotta be able to see outside in the dark right?
  9. Chinatown
    Chinatown Road Train Member
    Aug 28, 2011
    74,666
    Thanks Received:
    169,706
    Henderson, NV & Orient
    A can of hornet spray.
    Cetane+ and Fatboy42 Thank this.
  10. Joetro
    Joetro Road Train Member
    Aug 23, 2008
    2,416
    Thanks Received:
    2,409
    Post Falls, ID
    I have four hammers in my truck. A framing hammer, a large ball peen, a BFH and the hammer on the rear-end of my .45. To answer your question, though, a tire thumper would work, as would a can of wasp spray.
    Cetane+, Fatboy42 and TGUNKEL Thank this.
Thread Status:
