Setting clock on Volvo?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by IUFAN87, Mar 17, 2011.
  1. IUFAN87
    IUFAN87 Light Load Member
    Jun 22, 2009
    220
    Thanks Received:
    31
    All Over
    Ok, I feel stupid here. How do you set the clock on an 04 Volvo? Last time change I figured it out somehow. This time I cant figure it out to save my rear.:biggrin_25511:
  2. bulldozerbert
    bulldozerbert Medium Load Member
    Oct 5, 2008
    622
    Thanks Received:
    240
    Ontario
    cant help ya, but drove a new ford pick up, and had to get out the manual..............and then, it was as simple as ever, go figure. Lol
  3. IUFAN87
    Jun 22, 2009
    220
    Thanks Received:
    31
    All Over
    Thanks, but if I had the manual I would have already used it. :biggrin_25526:
  4. bulldozerbert
    Oct 5, 2008
    622
    Thanks Received:
    240
    Ontario
    it would help if they would all be standard, as in the same..............
  5. 123456
    123456 Road Train Member
    Oct 22, 2010
    10,555
    Thanks Received:
    5,746
    32179
    might need a teenager to assist..........
    they can figure that stuff out sooo easily !!!!!
  6. Lilbit
    Lilbit Road Train Member
    Aug 4, 2008
    16,583
    Thanks Received:
    12,232
    Let me check my logbook
    No kidding! When in doubt, ask a teenager!:biggrin_25521:
  7. trucker_101
    trucker_101 Heavy Load Member
    Apr 23, 2010
    941
    Thanks Received:
    639
    Alberta
    is it the clock on the computer trip thingy on the left side of the dash or is it the clock in the radio that you want to adjust? If it's the radio tell us the make & model number of it.
  8. Hardlyevr
    Hardlyevr Road Train Member
    Jul 30, 2009
    3,270
    Thanks Received:
    2,540
    Mapleton Depot,PA
    I have an '07 and you do it thru the dash, scroll down to time and distance section, and keep pressing the button til the time sections change.
    In the previous Century's I had, I would set the dash on dispatch (Central) time and the radio on home (Eastern), but in a Volvo setting the dash clock will change the radio clock too, they sync together eventually.
  9. IUFAN87
    Jun 22, 2009
    220
    Thanks Received:
    31
    All Over
    Finally got it. Thanks guys......Another question I've been wondering about. What is the switch on the right of the steering column that has a pic of a gas pump with two arrows pointing at a circle under it? It is a spring loaded momentary switch (only on when you are pushing it).
  10. Pablo-UA
    Pablo-UA Road Train Member
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    I'm not sure, please post a photo....
