Should I try to get inspected?
Discussion in 'Ask An Owner Operator' started by Dino soar, Jan 9, 2020.
  1. Dino soar
    Dino soar Road Train Member
    Dec 8, 2017
    4,791
    Thanks Received:
    26,878
    Soon I wiil be getting my tag and getting started. I wonder if when I do get started if initially I should try to get inspected right away.
    The reason I say this is because almost everything on my truck is new right now. The list is exhaustive but I have new brakes new drums new cams and bushings all new air cans new rear bushings and airbags all new Airlines new exhaust and on and on and on.
    I'm sure that if they want to find something wrong they will, but so much of my truck is new right now that now maybe the best time.
    Then I would have an inspection under my belt and maybe they would leave me alone for a while and my rating would improve.
    Does that make sense or is that a bad move?
    Upinsmoke Thanks this.
  2. starmac
    starmac Road Train Member
    Apr 11, 2019
    6,639
    Thanks Received:
    12,528
    Fairbanks Ak
    Generally you can set it up with the dot to get an inspection. I have done it several times and always got a sticker. I would not generally just ask for one when crossing a scale.
    Bean Jr. and Upinsmoke Thank this.
  3. Dino soar
    Dec 8, 2017
    4,791
    Thanks Received:
    26,878
    Well I am going to be audited by a Pa puc officer. That may not be the right name for him but he's from the PA puc I believe.
    I do not know if that is THE audit or if dot will audit me also. Does anyone know that?
    If he were to inspect me, is that the same as a dot inspection? I am assuming he is a dot officer?
  4. xsetra
    xsetra Road Train Member
    Aug 21, 2011
    5,115
    Thanks Received:
    6,983
    I would just drive. The computer records will show you're new.
    You will get inspected soon enough.
    Good luck.
    Bean Jr., Upinsmoke and Dino soar Thank this.
  5. SteveScott
    SteveScott Road Train Member
    Nov 10, 2015
    4,897
    Thanks Received:
    16,806
    You can go into a scale and request an inspection. Some will and some won't do one on request. Just make sure EVERYTHING is in order before you go in. Getting an out of service on your record while having new authority is not a good thing. Go in for your annual inspection on the truck and trailer before attempting to get one from a scale house. Most places that work on trucks also offer the annual inspections. I got mine done at a Speedco.
    The DOT auditor will not do an inspection of your equipment. He just wants to see all of your records and paperwork.
    201 and Dino soar Thank this.
  6. 201
    201 Road Train Member
    Apr 16, 2014
    12,335
    Thanks Received:
    25,221
    high plains colorado
    I wouldn't run without that sticker, do they still have those, on the door? Used to be, you could buy those stickers at a truckstop, along with blank health cards . I'm sure they did away with that by now. I wouldn't volunteer going into a scale for ANY reason.
    snowwy and TheLoadOut Thank this.
  7. xsetra
    Aug 21, 2011
    5,115
    Thanks Received:
    6,983
    Annual inspection sticker and forms are for sale in some truckstops.
  8. Oscar the KW
    Oscar the KW Going Tarpless
    May 19, 2011
    12,246
    Thanks Received:
    28,116
    You can ask at a scale for all the inspections that you want, but they will not change your safety rating. An audit is the only thing that will change that.
  9. TheLoadOut
    TheLoadOut Road Train Member
    Nov 6, 2019
    2,254
    Thanks Received:
    10,692
    I would think walking into the scale and asking for an inspection with the thought being that everything is in order almost makes them look even harder and maybe even has them come up with some petty violation because you made them work. I wouldn't stick my hand into a bees nest for some honey, and I'm not walking into a scale to ask for an inspection.
    201 and Mountaintrucker4302 Thank this.
  10. m16ty
    m16ty Road Train Member
    Jan 22, 2016
    2,269
    Thanks Received:
    4,957
    Just drive, you'll get inspected soon enough. There is no way I would volunteer for a DOT inspection.
    TheLoadOut and SL3406 Thank this.
