Single axle tractor with step decks
Discussion in 'Ask An Owner Operator' started by Stroked F550, Dec 10, 2014.
  1. Stroked F550
    Stroked F550 Medium Load Member
    Jan 23, 2008
    325
    Thanks Received:
    42
    somewhere
    hey guys
    Is anyone running a single rear axle tractor with a step deck?
    What kind of axle weights are you running?
    What loads are you hauling? ( can you posts pics)
  2. Hurst
    Hurst Registered Member
    Aug 24, 2011
    6,618
    Thanks Received:
    12,266
    Tampa, Fl
    I delivered in Miami a few weeks back and I saw a guy come in with a regular flat bed and a single axle Freightliner.
    The problem I see is that Step deck already adds some weight over a regular flat. Now your reducing the (Normal) weight a step deck would carry on the drives.
    To be successful you'll need to be versatile. I dont see that happening with a single axle. Your castrating yourself. You need to be able to scale at least 45k lbs on the deck. Unless your going into a niche and have a dedicated shipper with light loads,.. I'm not sure how you will make it work.
    I'm not saying you cant. I saw that guy running one. So it must be doable. I doubt he's making the same money as someone with tandem drive axles. Just my opinion. Take that with a grain of salt.
    Hurst:smt111
  3. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,527
    Thanks Received:
    13,265
    yep, your adding about 1500 pounds to the trailer empty weight, while taking away 14,000 pounds you can haul on the single drive axle, that's 15,500 pounds less weight you can haul.
    you'd have to have light loads that would be trailer heavy.
  4. Stroked F550
    Jan 23, 2008
    325
    Thanks Received:
    42
    somewhere
    thanks guys for the responses
    all I need to haul is about 18k -20klbs
  5. 281ric
    281ric Road Train Member
    Oct 20, 2011
    1,248
    Thanks Received:
    809
    TX
    I see a few hot shot set up like that down here in TX.
  6. Al. Roper
    Al. Roper Road Train Member
    Apr 21, 2013
    1,511
    Thanks Received:
    10,720
    Bakersville NC
    I know a couple of guys with that exact setup. They can scale 25k with no probs. tagged for 54k I believe.
  7. BAYOU
    BAYOU Road Train Member
    Sep 23, 2010
    2,847
    Thanks Received:
    1,592
    Beaumont,Tx
    Did it for years just like with anything else you just need to watch where you put your load I was 70,000 gross and moved lots of 40,000lb loads
    Hurst Thanks this.
  8. Blind Driver
    Blind Driver Road Train Member
    Aug 7, 2006
    3,081
    Thanks Received:
    1,406
    New Albany, IN
    That's what I was thinking. The spread can haul 40k lbs and most loads are under 60k gross:)
  9. BAYOU
    Sep 23, 2010
    2,847
    Thanks Received:
    1,592
    Beaumont,Tx
    I went years and never hauled loads over 30,000lbs I ended up adding a axle for a customer I had that was moving 45,000lb loads. I did move them for some time until the rear bags started blowing.
  10. Brandonpdx
    Brandonpdx Road Train Member
    Dec 27, 2007
    4,219
    Thanks Received:
    4,018
    Elkhart, IN
    Technically you have two 20k axles on a spread, not a 40k "group". They can nail you for one of being over 20k just like with the single drive.
