Sliding new frame rails in a truck? Cost of replacement?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Verschoot01, Apr 20, 2021.
  1. Verschoot01
    Verschoot01 Bobtail Member
    Mar 26, 2021
    Thanks Received:
    Truck I have has a bad rusted double frame, I think the first thing I'm gonna save a chunk of change for is to be able to take it somewhere to have a set of single rail frame slid in it, I've heard of it being done on trucks that were wreck and need a rail replaced..... Does anyone know a rough idea what it's cost to have a shop pull out my rails and replace em with single rails?
  2. DUNE-T
    DUNE-T Road Train Member
    May 10, 2015
    6,944
    Thanks Received:
    16,851
    Detroit, MI
    I got an estimate of $10k just for labor
    AModelCat Thanks this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    Aug 26, 2014
    4,476
    Thanks Received:
    6,513
    In about 1990 a roll off container Auto Car rail was $5,000.00. It even had all the holes drilled from the front bumper to the back of the cab. It was a three rail deal but only single up front. We welded the bad areas at shorter rails end. Then had eight foot long over lays made. Striped that section of the frame and bolted them all together. Added a cross member at the bad spot. That was an inch of drilling in some places. Saw the truck years later still running.
  4. AModelCat
    29,212
    Thanks Received:
    159,201
    I priced out rails directly from Paccar for mine 4 years ago. About $18k Cdn for 2 undrilled blanks.
    bbechtel16 and Bean Jr. Thank this.
  5. lester
    Jan 2, 2012
    2,920
    Thanks Received:
    7,890
    NW, Iowa
    PG Adam's, think they are east coast. Can get you rails. You can send your old rails and the will drill new ones the same or sometimes you can getbthe build sheet from manufacturer and the can drill off those. Or just plain rail and drill yourself
  6. bocker
    bocker Light Load Member
    Jun 29, 2018
    63
    Thanks Received:
    35
    Had one done 3 yrs ago $15,000 seemed going rate
    bbechtel16 Thanks this.
  7. Cattleman84
    Cattleman84 Road Train Member
    Nov 1, 2017
    9,925
    Thanks Received:
    70,822
    The Sticks, Idaho
    Straight rails can be fabricated by a reputable weld shop much cheaper than purchasing OEM... I have stretched several frames (added 10 feet to one particular truck) and we always had the additional frame fabricated... WAY cheaper than buying pre fabricated... The expenaive part about a complete frame replacement will be the labor, and I have no idea how much that would run.
  8. Dino soar
    Dino soar Road Train Member
    Dec 8, 2017
    4,791
    Thanks Received:
    26,878
    When you say fabricated what do you mean?
    There are some places that can roll you the right size Steel maybe in ten foot line length or so but there are very very few people places they can get you frame rails that are actually frame rails with the right tensile PSI.
    Those hardened steel frames can't be bent up on a regular press the way mild steel can. So there are not a lot of places that you can get them that I'm aware of.
  9. Cattleman84
    Nov 1, 2017
    9,925
    Thanks Received:
    70,822
    The Sticks, Idaho
    Yeah its A36 steel. Has a tensile strength of 36k. And you are correct it does take a very large hydraulic break to bend it, but there are weld shops out there that can do it. I can think of 3 within 50 miles of my home, 2 of which I have personally done business with. Look for weld and fabrication shops that specialize in large farm or construction equipment.
    Edit: Anither option is to form them from high carbon, low tensile steel amd then have them heat treated (thats how OEMs do it)... But that requires a very large heat treating oven, which most places dont have.
    BoxCarKidd Thanks this.
  10. Dino soar
    Dec 8, 2017
    4,791
    Thanks Received:
    26,878
    I have a place near me that will bend up A36. It is relatively inexpensive compared to buying frame rails from PG Adams. But the frames from PG Adams have over 100,000 PSI tensile strength. My understanding is that is the same as the OEM.
    I'm honestly not certain about using a A36. On one hand it really is mild Steel, and if you think about it the strength of a frame is such that when it flexes because it's all the same tensile steel you get the same Flex. On the other hand, because the section you're going to put in has reinforcement inside, that may be less of an issue.
    But the length that you install behind it will not have the same strength as the original frame and may give you more Flex than the original frame. And it will not be as strong.
    I'm not really sure what to think about that except that in theory anyway it's best to match the yield strength of the original frame.
    Actually the best of all is probably to find a cutoff or actually long pieces of frame from the same kind of a truck if the rails are in good shape. I would think A36 is probably okay for the reinforcement.
    How did the A36 work out for you?
    Cattleman84 Thanks this.
