Slow Air Build Up With Heavier Loads
Discussion in 'Questions From New Drivers' started by SavageSwat, Sep 30, 2022.
  1. SavageSwat
    SavageSwat Bobtail Member
    Sep 30, 2022
    Thanks Received:
    2015 KW T680 isx15
    Question i have no air leaks or anything, but when i carry a light load truck air works as usual. But if i carry a load over 30k when my air get below 90psi it build back up really slow. While driving down the road. If it get down to 75psi takes about 8 minutes to build back over 100 psi. Anyone have this problem? Took my truck to kenworth and since it was no load they said they couldn't duplicate the problem.
  2. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,836
    ga
    Ck for any cracks in the lower part of air bagss that are are showing when it's loaded loaded heavy, and leveling valves leaking?
  3. Dave_in_AZ
    57,133
    Thanks Received:
    390,237
    Air bags on suspension, or air bags on cab. Cab typically bleeds fast though.
    Since it does it when you're loaded, I'd go with suspension.
    Do yourself a favor and replace all 4 and the fittings at the same time.
    And as long as you've gone that far, do the two on the cab.
  4. Rideandrepair
    Aug 8, 2015
    17,348
    Thanks Received:
    56,288
    Maybe spray some water on connections, checking for leaks before changing parts. If I had to guess, first place I’d check is the leveling valve on suspension. The arm may be sloppy, and less responsive, maybe even leaking a bit, or sometimes sticking. Try to wiggle the arm, see if it’s loose, and make sure the rod it’s attached to isn’t loose or missing a rubber bushing.
    MartinFromBC Thanks this.
  5. Espressolane
    17,586
    Thanks Received:
    107,838
    Agree, air bags and leveling valve would be the first things to look at. Both truck and trailer.
    SavageSwat Thanks this.
  6. lester
    Jan 2, 2012
    2,920
    Thanks Received:
    7,890
    NW, Iowa
    Are constantly loosing air and building back up? Like driving down the interstate are you loosing air pressure or is it when you are using your brakes that you loose air pressure?
    SavageSwat and MartinFromBC Thank this.
  7. Magoo1968
    Magoo1968 Road Train Member
    Mar 18, 2021
    2,032
    Thanks Received:
    5,426
    St Malo mb
    You’re air should never drop to 90 YOU HAVE a air leak or compressor isn’t pumping.
    lester Thanks this.
  8. Ridgeline
    22,421
    Thanks Received:
    116,718
    I had a truck that was doing something like this, it turned out to be the leveling valve and the valve to drop the air in the bags. When the load was on the truck, the valve was worn enough where it would bleed the air off. the valve was also leaking which was unusual.
    Magoo1968 and SavageSwat Thank this.
  9. SavageSwat
    Sep 30, 2022
    Thanks Received:
    Hello fellas i did some checking and foundvout that my air bag leveling arm was leaking air. If i touch it it would blow air from the bolt coming out. Sad that it was at the Kenworth shop for a month and they couldn't figure that out, smh $900 for nothing. Thanks guy hopefully that will fit it i changed it today $177.
    Magoo1968 Thanks this.
  10. SavageSwat
    Sep 30, 2022
    Thanks Received:
    Exactly what mine was doing i changed it today, i moved the arm a tiny bit it started blow air from the arm bolt
