Sorta dumb question? Ask it here.
Discussion in 'Questions From New Drivers' started by Bill51, Feb 27, 2019.
  1. Bill51
    Bill51 Road Train Member
    Jul 27, 2015
    1,180
    Thanks Received:
    2,973
    I'll start.
    At the Love's for my 30 min break. It's 22F outside. Why is the reefer unit on the trailer next to me running??
  2. buddyd157
    buddyd157 Road Train Member
    May 25, 2017
    13,566
    Thanks Received:
    34,855
    under a shade tree
    to keep the load from freezing.
    temp controlled loads have to be maintained. if some (or all) of product freezes, it can be denied at the receiver..
    Bill51, Suspect Zero, Lepton1 and 2 others Thank this.
  3. Cattleman84
    Cattleman84 Road Train Member
    Nov 1, 2017
    9,925
    Thanks Received:
    70,823
    The Sticks, Idaho
    My reefer never shuts off when I have a temp controlled load on board... Most my loads are in the 35 to 50 degree range, depending on what it is.
    Bill51, Swiss Mountain Dog and x1Heavy Thank this.
  4. gokiddogo
    gokiddogo Road Train Member
    Mar 5, 2012
    8,786
    Thanks Received:
    14,768
    Ontario Canada
    Those leafy green produce loads can be damaged at even a few degrees below their typical 34° set point..
    The on/off mode is more for do not freeze, or frozen loads, you can get away using it with some produce like potatos, onions, oranges, etc. The heartier ones. Or if you haul chocolate or other commodities where it's fine anywhere between say 40 and 65 degrees or whatever. Anything leafy green or any kind of berry must be kept on continuous.
  5. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,137
    White County, Arkansas
    It's either heating, for medicines on my rig or it's cooling at -20 for either dough, ice cream etc.
    Bill51 Thanks this.
  6. bryan21384
    bryan21384 Road Train Member
    Sep 18, 2009
    14,926
    Thanks Received:
    32,373
    Memphis, TN
    You never know what someone is hauling. Right now I'm moving a lot of paint. Sherwin Williams won't be as quick to load a dry van if the load goes north. I have to set the reefer at 55 degrees. If its 22 degrees, the reefer will come on fairly often
  7. Chinatown
    Chinatown Road Train Member
    Aug 28, 2011
    75,085
    Thanks Received:
    171,226
    Henderson, NV & Orient
    Same here. Better safe than sorry.
    Cattleman84, x1Heavy and Lepton1 Thank this.
  8. x1Heavy
    Mar 5, 2016
    34,017
    Thanks Received:
    42,137
    Same. All my loads were continuous. If it needed it or not.
    Maybe a few is cycle. But personally it's on or don't bother with it at all.
    Cattleman84 Thanks this.
  9. Cattleman84
    Nov 1, 2017
    9,925
    Thanks Received:
    70,823
    The Sticks, Idaho
    Also makes it easier to sleep without that Freight Train starting up and shutting down all night long.
  10. 6wheeler
    6wheeler Road Train Member
    Aug 30, 2009
    2,696
    Thanks Received:
    4,774
    Here is my dumb question.
    How come van driver's back the overhang of the trailer into light polls, tree's, concrete barriers and hillsides?
