Starting this week Mack CH613
Discussion in 'Questions From New Drivers' started by MackCH, Mar 25, 2012.
  1. MackCH
    MackCH Bobtail Member
    Mar 25, 2012
    Thanks Received:
    Ganado, Texas
    Guys I'm starting a new job changing careers to hauling saltwater in the oil field. I'm having trouble getting in touch with my boss cause he's on location in the new oil field find in Texas. All I know is that I'll be driving a CH613; i'll be pulling the long version of a vacuum truck with the long full sized tank.... there are so many models of the CH. Which model would be the truck for the oilfield vacuum service... I need a few models and probable transmission; number of gears so I can watch some instructional videos before I start and learn as much about the CH before I start... By the way does the CH have a good reputation?
  2. CenutryClass
    CenutryClass Road Train Member
    Feb 15, 2006
    1,539
    Thanks Received:
    859
    macks dont make the most aesthically pleasing trucks, but those things are tanks and can take a beating..Still see early 90's model macks running around. real strong, solid trucks.
  3. DrtyDiesel
    DrtyDiesel Road Train Member
    Feb 14, 2010
    5,348
    Thanks Received:
    2,598
    Jacksonville, FL
    My favorite is the rawhide editions. Big hood with the huge flat grill.
    Ethan
  4. oldmack
    oldmack Light Load Member
    Apr 9, 2011
    52
    Thanks Received:
    42
    philadelphia, pa
    Just google CH16 there are only two models of CH613 the CH and CHN. The visions are CH, CHN, CX, and CXN. Pinnacles are CHU, CXU , and CXP. The truck in my profile pic is a 99 CH613 with an MP7 350 with a 9 speed. Mack had the same transmissions as the other trucks but also had their own transmissions, all standard shift patterns. The mack transmissions. The rawhide is a pinnacle with some high end components and a CH hood. After 2007 Volvo merged with Mack so the pinnacle and rawhide models have volvo undercarriages and drive lines with a mack cab. The engines are volvo engine with mack valve covers and mack part numbers. If you look at a 2008 Mack and Volvo side by side you will see the comparisons. The older CH613's are god awful tough but not the most comfortable.
  5. MackCH
    Mar 25, 2012
    Thanks Received:
    Ganado, Texas
    that's probably exactly what i'll be driving; will check on the other models though; your truck looks like its is what we would use in the oilfield on gravel and dirt roads,
    thanks,
    Mark
