Steering wheel shaking side to side when brakes under 40 mph
Discussion in 'Ask An Owner Operator' started by Buya, Sep 22, 2018.
  1. Buya
    Buya Bobtail Member
    Apr 29, 2018
    41
    Thanks Received:
    17
    Steering shakes when brake under 40mph and almost all parts new orn front when i open front break open like no break on front and hit breaks no more shaking means what it could be? Drums tires break shoes new
  2. Midnightrider909
    Midnightrider909 Road Train Member
    Oct 26, 2016
    2,383
    Thanks Received:
    9,599
    Loose/worn ball joints and or suspension attachment points?
    InTooDeep Thanks this.
  3. fargonaz
    fargonaz Road Train Member
    Feb 9, 2015
    1,167
    Thanks Received:
    4,583
    Mesa, AZ
    It's not uncommon to get out-of-round chinese drums. Bad bushings, kingpins, etc.
  4. Midnightrider909
    Oct 26, 2016
    2,383
    Thanks Received:
    9,599
    If it were a car I’d say warped brake rotors.
  5. colorado18spd
    colorado18spd Medium Load Member
    Mar 10, 2013
    396
    Thanks Received:
    298
    1st. Adjust the brakes it's the cheapest starting point.
  6. Ridgeline
    22,463
    Thanks Received:
    117,767
    Wasn't this already talked about in another thread?
    Maybe the OP needs to read that thread?
  7. Buya
    Buya Bobtail Member
    Apr 29, 2018
    41
    Thanks Received:
    17
    Adjusted couple times same just loosen break shoe all the way hit break no more shaking cannot figured out whats the problem
  8. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,787
    Thanks Received:
    6,223
    Warped drums.
  9. aussiejosh
    aussiejosh Road Train Member
    Aug 28, 2009
    4,709
    Thanks Received:
    5,409
    Airlie Beach QLd
    Ummm a flat tyre ? wheels out of balance ? something is outta wack thats for sure better go suss it out dude.
  10. Derailed
    Derailed Road Train Member
    Dec 10, 2008
    2,383
    Thanks Received:
    2,657
    Upstate NY
    Jack each side up and rotate the wheel by hand. Look between the shoe surface and drum while spinning. Being new drums with mine you could clearly see they were warped along with the uneven wear surface where the shoe was hitting the drum when the brakes were applied.
    fargonaz Thanks this.
