Stuck bolt on cab shocks. Will I have to cut them?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by feldsforever, Aug 26, 2021.
  1. feldsforever
    feldsforever Road Train Member
    Nov 22, 2019
    1,453
    Thanks Received:
    1,440
    Right side top bolt of the cab shocks.
    Not one of the big six. But one of the two on the sleeper birth. Driver side bolts came right out. The pasenger side top bolt, after about 40 mins with penetrating fluid a hammer and a breaking bar. Tightening it and loosening it. It is now spinning. But with great resistance. I don't mind taking a angle grinder to it. I just don't know what to replace it with. Keep in mind I do have the nut and washer off. It seems to be rusted together on the bolt head side. But no visual rust.
    Thanks in advance. I was feeling mister professional Untill this happened.
    All new shocks. New light on Tommrow. And new passenger side bumper. And this is holding me up.
  2. Roberts450
    Roberts450 Road Train Member
    Feb 6, 2016
    2,237
    Thanks Received:
    3,638
    Can you put the nut back on a few threads and whack it with the hammer to try and drive the bolt out? A picture would be much helpful in this case.
    Dino soar and RedForeman Thank this.
  3. 062
    062 Road Train Member
    Oct 20, 2013
    6,276
    Thanks Received:
    33,783
    I don’t know how they’re mounted on the truck, but has the air bled off and put it in a bind?
  4. Rideandrepair
    Aug 8, 2015
    17,430
    Thanks Received:
    56,539
    Shops usually use a torch, cut the shock off the bolt, then cut the bolt off, once shocks out of the way. The bolts rusted to the steel bushing in the shock. Maybe you can cut the shock out of the way, then cut the bolt, twice if you have to if the steel bushing won’t budge, Might be able to grind the bushing off.
    kwcam, TallJoe and feldsforever Thank this.
  5. TheLoadOut
    TheLoadOut Road Train Member
    Nov 6, 2019
    2,355
    Thanks Received:
    11,211
    Sounds like you have my luck, I'll start a job, with hesitation, then as things are going smooth I'm like "hey, this isn't so bad" then whammo!...usually when I'm just about to finish, some stupid thing happens and now it becomes a project.
    Dino soar, JoeyJunk, xsetra and 4 others Thank this.
  6. RedForeman
    RedForeman Momentum Conservationist
    Jan 30, 2011
    4,875
    Thanks Received:
    22,141
    I would agree with this. You'll have to cut it out somehow, avoiding the bracket of course. Battery powered side grinders are awesome for jobs like this. I carry this one in my Ryobi bag of tricks. Sold at Home Depot.
    To replace, take one of the other bolts you didn't cut up to a hardware store, and buy one just like it. Don't worry about the sleeve that's spinning around in your old one - the new shock will come with it already pressed in. In my area Ace Hardware or True Value stores have the best bolt selections, especially in stainless. Home Depot and Lowe's are usually picked over crap, and never have what I need, or if they do, they don't have enough of them.
  7. Rideandrepair
    Aug 8, 2015
    17,430
    Thanks Received:
    56,539
    Lot of anti seize on the whole bolt, makes next time a breeze.
    Oxbow, Dino soar and feldsforever Thank this.
  8. RedForeman
    Jan 30, 2011
    4,875
    Thanks Received:
    22,141
    I miss shopping my local Ace Hardware store since buying a stainless bolt assortment. His kids are probably going to have to drop out of UGA and attend a junior college somewhere, now that I'm not in there once or twice a week paying full retail for single bolts and whatnot.
  9. Dave_in_AZ
    59,324
    Thanks Received:
    411,638
    I had blowout on the trailer cripple that angle piece that runs across the trailer the mud flaps bolt onto.
    Four 1/2" bolts, cut the head off the last one with a hack saw.
  10. Spyro2112
    Spyro2112 Medium Load Member
    Mar 17, 2018
    609
    Thanks Received:
    414
    Jack, level. Heat, pound
