Surging C12
Discussion in 'Kenworth Forum' started by CbarM, Mar 2, 2013.
  1. CbarM
    CbarM Heavy Load Member
    Jan 17, 2011
    894
    Thanks Received:
    247
    Irvine, AB
    Hey guys, I have a 2000 T600 with a C12 and when its below freezing it starts surging really bad beteeen 10 and 20 lbs of boost. It does it at all RPM's. New fuel filters and air filter. It will make 30 lbs of boost no problem, but the surging is ao bad that it will start slapping the driveline back and forth till either I get more then 20 lbs of boost or let off the pedal completely. Any ideas? Even the local Cat shop has no idea as they couldnt pull any codes at all...
  2. bullhaulerswife
    bullhaulerswife Forum Leader/Admin Staff Member Administrator
    Jul 23, 2007
    28,279
    Thanks Received:
    44,389
    Midwest
    Moved this over to the Kenworth forum for you. It will get better attention in here. :biggrin_25525:
  3. CbarM
    Jan 17, 2011
    894
    Thanks Received:
    247
    Irvine, AB
    Thank you, I appreciate it.
  4. dicky
    dicky Bobtail Member
    Aug 16, 2008
    31
    Thanks Received:
    8
    st.paul , mn.
    do you know if you have a multi-torque program in it?
  5. CbarM
    Jan 17, 2011
    894
    Thanks Received:
    247
    Irvine, AB
    Multi torque is off. It started doin this a coiple months ago n has gotten worse. No mods to ecm at all
