Swapping a 2ws engine into a BXS Truck.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by marksconst, Feb 24, 2014.
  1. marksconst
    marksconst Bobtail Member
    Jan 10, 2014
    5
    Thanks Received:
    I have a Truck with a C-15 Acert BXS engine that just broke the crank. I have a fresh reman 2WS engine in a wrecked pete. My question is, could I Use the 2ws in its place with a lil modification?
    Thanks
    Mark
  2. highside
    highside Medium Load Member
    Feb 6, 2010
    441
    Thanks Received:
    510
    Kansas
    Should drop in with little trouble.
  3. BigJls1
    BigJls1 Medium Load Member
    Dec 25, 2012
    482
    Thanks Received:
    415
    Red Rocket 1964 Thanks this.
  4. wore out
    wore out Numbered Classic
    Jun 5, 2013
    16,644
    Thanks Received:
    203,213
    CHASIN THE DEVIL'S HERD
    With the conversion harness it shouldn't be a big deal at all. Since you have the 2WS already it's probably the cheapest fastest way to go.
  5. swaan
    swaan Road Train Member
    Jul 12, 2009
    2,942
    Thanks Received:
    4,374
    BC canada
    The truck side harness should be the same 70 pin plug. 2ws has that plug so no harness is needed.
    Engine mounts are the same. Coolant pipes are the same. Only things are intake air pipping and air to air on hot side and exaust. Will all need a little fab work as turbo is in a different location. Not really a big deal. Once every thing is installed you'll probley need a few tweaks to the 2ws ECM to get everything working correctly.
  6. Eustace
    Eustace Bobtail Member
    Jan 28, 2014
    47
    Thanks Received:
    12
    Swaan is correct, you won't need any harness. It's almost all plug and play.
  7. ROBSREDFORD
    ROBSREDFORD Light Load Member
    Sep 2, 2008
    266
    Thanks Received:
    139
    MIDLAND, NC
    Plug n play except for turbocharge piping both discharge and air cleaner inlet....use the mounts off the bxs due to changes in engine placement.... I'd be interested in the bxs 7045072453
  8. marksconst
    Jan 10, 2014
    5
    Thanks Received:
    good deal. I already started pulling the motors on both trucks and it was looking like it would work with little fab work. I couldn't find a replacement engine unless it had 800,000 miles on it unless I wanted to pay 12k. Thanks guys for the info.
  9. little cat 500
    Jan 17, 2010
    2,055
    Thanks Received:
    1,100
    Abbottstown PA
    thought you had to move some pins around i think the injector pins
  10. highside
    Feb 6, 2010
    441
    Thanks Received:
    510
    Kansas
    He's swapping complete engines - not just the ECM's.
