Swaying issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Oct 10, 2017.
  1. truckerbangin
    truckerbangin Light Load Member
    Jan 22, 2013
    264
    Thanks Received:
    44
    Good day all. I have a fld112 single axel with a second set of brand new tires on the rear and the truck sways really bad also driver noticed Truck pulls to the right when he lets go of steering wheel.
  2. boneebone
    boneebone Road Train Member
    Mar 13, 2009
    2,295
    Thanks Received:
    2,366
    Usually a new set of drives will give the sensation of the truck swaying or the rear fishtailing because the tread blocks on the drives are really squirming around.
    It usually takes a few hundred miles before the tires settle in.
    The pulling may mean you need an all axle alignment.
    I would check the front suspension drag link, tie rods and springs and hangers and also the rear suspension components too.
    MACK E-6 and Heavyd Thank this.
  3. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,767
    Thanks Received:
    6,204
    I agree with boneebone.
  4. MACK E-6
    48,719
    Thanks Received:
    224,898
    Drive tires will do that until a wear pattern gets established. This is especially noticeable on a single screw.
    I HATE when they put new tires on mine.
    Heavyd Thanks this.
  5. truckerbangin
    Jan 22, 2013
    264
    Thanks Received:
    44
    thanks for all the input guys
  6. aussiejosh
    aussiejosh Road Train Member
    Aug 28, 2009
    4,709
    Thanks Received:
    5,409
    Airlie Beach QLd
    I'd be checking the suspension shocks, and springs check the wheel alignment as well. Unless your driving in really heavy winds it should not be swaying about.
