Swift Rigs
Discussion in 'Questions From New Drivers' started by shifty, Apr 28, 2008.
  1. shifty
    shifty Light Load Member
    Apr 26, 2008
    95
    Thanks Received:
    12
    Conway, AR
    What kind of rigs does swift have for you when you get your own truck? and are they standard transmissions or can you get autoshifts?
  2. Working Class Patriot
    Working Class Patriot Road Train Member
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    Wherever and Whenever...
    Do you actually want to drive an autoshift???
    Real drivers shift their own gears and not let the truck tell them what to do.:biggrin_25525:
  3. shifty
    Apr 26, 2008
    95
    Thanks Received:
    12
    Conway, AR
    no i wanna shift but my wife isnt that great at it and we are a team. is the autoshift like a automatic in a car? or does it tell you which gear to be in and you still have to shift
  4. Working Class Patriot
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    http://www.roadranger.com/Roadranger/productssolutions/transmissions/autoshift10-speed/index.htm
  5. shifty
    Apr 26, 2008
    95
    Thanks Received:
    12
    Conway, AR
    " The clutch is used only for starting" that part right there is the part that my wife cant do lol. do you have to work the throttle like a regular standard tranny?
  6. Working Class Patriot
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    There is a video on Fuller's site and from what I recall, once you get going you just drive it like a 4 wheeler with an auto.
    Me personally, I prefer to shift the gears myself. But that's just me oh, and two sticks are better than one btw:biggrin_25523:
    [yt="Twin Stick"]w7d6OZs8cI8[/yt]
  7. Sportster2000
    Sportster2000 Road Train Member
    Jan 5, 2008
    1,480
    Thanks Received:
    886
    Indiana
    All right now, you have the Eaton Fuller autoshift and the Eaton Fuller Ultrashift. Yes you have to use the throttle just like you would normally. The autoshift has a clutch that you do have to use during take off and stopping. The Ultrashift does not have a clutch pedal, the clutch is a centrifugal style clutch meaning that when the rpm picks up to a certain speed it engages. They both shift slow. They both are not as good as what a manual would be on a hill, but then you don't have to worry about missed shifts with these transmissions either. They do have a manual mode on them. You basically push a up or down button for shifting, but the engine has to be within a certain parameter before it will let you shift up or down. I believe that the last one I drove it had to be above 1500 rpm to up shift and below 1300 rpm to down shift. If you down shift and the rpms pick up above 1500 rpm in auto mode it will then up shift. You can sometimes shift manually with it in auto mode. So times it will not let you. I have found that if you use a manual trans vs an auto that you can get to a top of a hill 5-10 mph faster because you can pick a gear that it says it is running to high a rpm in a manual but not an auto. I hope this helps you out.
    Sorry, forgot to mention the meritor auto and the allison automatic. The meritor is similar to the eaton except that you have a paddle that you have to move for it to shift. Foward is up shift backwards is down shifting. Allison automatics are just like a car. Set it to drive and go.
  8. shifty
    Apr 26, 2008
    95
    Thanks Received:
    12
    Conway, AR
    What about these new volvo i-shifts?
  9. Working Class Patriot
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    Here you go:
    [yt="Autoshift"]9eT0IZmPId8[/yt]
  10. Lurchgs
    Lurchgs Road Train Member
    Feb 13, 2008
    2,122
    Thanks Received:
    308
    Denver, CO
    Already I miss the clashing of gears as I hammer the clutch to the floor
