T680 CEL lights on, keep running?
Discussion in 'Kenworth Forum' started by 59EX, Sep 20, 2016.
  1. 59EX
    59EX Medium Load Member
    Jun 27, 2015
    407
    Thanks Received:
    631
    So I got these two on this morning. My shop says I need to bring it in. But for future reference could I keep running with these on for a week or two before getting to the shop or will it derate.
    Just trying to get a sense of these lights are truly the indication of a real immidiate issue or just idiot lights for emissions stuff.
    TIA.
  2. pcfreak
    pcfreak Heavy Load Member
    Apr 22, 2007
    835
    Thanks Received:
    385
    Alberta, Canada
    Depends on the severity of the issue causing them. Likely will not derate. Just something you should get checked as soon as possible because there is a possibility it could lead to larger problems if not dealt with.
    59EX Thanks this.
  3. Cottonmouth85
    Cottonmouth85 Bad Influence
    May 3, 2012
    2,637
    Thanks Received:
    8,701
    Floresville, Tx
    What does it say on the diagnostic display?
  4. pcfreak
    Apr 22, 2007
    835
    Thanks Received:
    385
    Alberta, Canada
    If it is derated, it may tell you when you go through the diagnostic area of the in dash display. It will say something like "Derate". Then again, it may not and be only visible to a connected computer.
    But driving it will tell you as well. Low power, pretty sluggish.
    Yellow check engine lights aren't too much to get excited over. It's just a "Something needs checking" indicator. If you get ones that are red, then you have a real problem. They will literally shut you down.
    59EX Thanks this.
  5. Cottonmouth85
    May 3, 2012
    2,637
    Thanks Received:
    8,701
    Floresville, Tx
    If it's emissions related yellow can go to red reeaall quick. Or it could blink yellow for a month. It's a crap shoot.
    In my experience a wrench light usually came with a derate and was a 'final warning'.
    But unless you enjoy riding shotgun in a tow truck best check it out.
    59EX Thanks this.
  6. 59EX
    Jun 27, 2015
    407
    Thanks Received:
    631
    Thanks, appreciate the quick responses. The truck is in the shop now.
    Cottonmouth85 Thanks this.
  7. 59EX
    Jun 27, 2015
    407
    Thanks Received:
    631
    Nothing. The truck did derate though. I was empty and was having issues with pulling hills.
  8. JKrabs
    JKrabs Bobtail Member
    Oct 1, 2016
    34
    Thanks Received:
    40
    Just for future reference, The one with a wrench is a check engine light. The one without a wrench is the malfunction indicator lamp. The MIL indicates an emissions-related fault code (EPA requires certain failures of parts to illuminate an MIL). The CEL is everything else. It's rare on modern tractors that you'll have one light without the other.
    Also, no one can tell you if the truck will derate based on which light is on. Some fault codes derate after 15 miles from first MIL illumination, some fault codes cause a derate 250 miles after the MIL illuminates.
    59EX Thanks this.
  9. andagon329
    andagon329 Bobtail Member
    Jun 14, 2020
    Thanks Received:
    Mine came on with a MIL only and it does that for a day or two and then goes away never derrates or acts up. I took it in to a shop and they said it was a oil temperature sensor went bad. The gauge for the front differential oil temp doesn't work so I think that might be it but why would it came up with a MIL light. Its a mistery to me. Any thoughts ?
