THANKS FOR HELP --------Which day cab will be able to haul tri-axle end dump trailer?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by c.w, Mar 19, 2024.
  1. c.w
    c.w Light Load Member
    108
    48
    Jun 26, 2021
    my friend , he just got some job to haul tri-axle end dump. we getting confused about how to choose a right day cab and right axle.
    some one saying that tri-axle end dump needs 20k lbs steer axle, but why? is any changes when lift the box?
    he just interested in a 2008 International prostar day cab,
    450 hp , 18spd standard tranny, 205 wheel base,
    steer axle 12K , drive axle 40k lbs
    Is this truck will be able to handle a dump trailer?
    Thanks!
  3. RockinChair
    RockinChair Road Train Member
    5,229
    13,503
    Feb 19, 2012
    Lubbock, TX & thereabouts
    How heavy are the loads, and what type of end-dump is it?
    Bean Jr. Thanks this.
  4. abyliks
    abyliks Road Train Member
    3,997
    9,397
    May 2, 2010
    ludlow MA
    Where is he located?
  5. c.w
    108
    48
    Jun 26, 2021
    35ft tri-axle end dump with around 60-62k lbs sand,trailer tare weight will be 20k lbs , terrain almost flat
    Thanks
  6. c.w
    108
    48
    Jun 26, 2021
    Central Canada------North dakota
    no mountains
    THANKS
  7. Cat sdp
    Cat sdp . .
    21,183
    75,084
    Apr 8, 2012
    Orion's Belt
    It will do the job, not the best setup but this is the new way…..
    46k rears and a 13-14k front would be nice. 24.5 talls with 3.70-4.10 gear and a 550 would be top shelf…..
    stwik, NightWind and c.w Thank this.
  8. bluerhino
    bluerhino Light Load Member
    107
    7
    Mar 10, 2013
    Hi seems you no more about end dump trailer will a mack or kw day cab with wet kit be a good fit to sand and gravel.Best Regards
  9. Sons Hero
    Sons Hero Road Train Member
    2,733
    27,664
    Jan 8, 2021
    Indiana
    Both are solid trucks. Looking at a 20 year old truck, I’d go for the Mack. Newer, go KW. They both come in a broad range of specs, some of which are better for end dumping than others, for instance, you likely won’t want a 300” wheelbase, and 2.26 rears for pulling a dump.
    OliverCallenderIII Thanks this.
  10. OliverCallenderIII
    OliverCallenderIII Light Load Member
    79
    53
    Aug 4, 2022
    Frisco, Texas
    2.26 rears for pulling a dump. What is this and how does it come into play on different truck and trailer combinations?
    Thanks in advance!
  11. NightWind
    NightWind Road Train Member
    2,714
    19,164
    Nov 11, 2006
    Sunny South, AL
    A Triaxle is a truck has 3 axles under the bed.[​IMG]
    Many of them Most weigh 20,000lb on the steering.
    If your pulling a triaxle trailer [​IMG]
    rarely will you exceed 12,500lbs on the steering.
