TIME OR NOT TIME TO OVERHAUL
Discussion in 'Kenworth Forum' started by lady doe, Jan 1, 2016.
  1. lady doe
    lady doe Light Load Member
    May 25, 2014
    72
    Thanks Received:
    4
    t2000 it smokes some, don't use too much oil between changes about a gallon after 7 to 8 thousand miles on the oil change, it runs good, get 7 mile to gallon got over a million miles on it. like 4 more payments. is it time for a over haul.
  2. josh polk
    josh polk Light Load Member
    Dec 20, 2015
    142
    Thanks Received:
    64
    Bowie TX
    There will b a hose that hangs down by the steer axel that come from the valve cover called blow by when it starts to have lots of air coming out of it covering ur truck with oil it's Time to overhaul 1 gal in 7k miles is great I'd say it's no were close
    Do u know any history on the motor
    I'd say it need the overhead ran for sure
    Hope this helps
    blairandgretchen and lady doe Thank this.
  3. 062
    062 Road Train Member
    Oct 20, 2013
    6,205
    Thanks Received:
    33,434
    Need to pull a oil sample,see what kind of wear metals you have.
    Put it on a dyno and find out how much blow by you have.
  4. peterbilt_2005
    peterbilt_2005 Medium Rare
    May 4, 2013
    3,906
    Thanks Received:
    29,189
    Commie-fornia come visit we have C. A. R. B
    OP
    What motor type do you have? CAT(yellow) ISX(Red), Detroit(green/gray)????
    Do you have the money for an Inframe rebuild?
    lady doe Thanks this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    Aug 26, 2014
    4,469
    Thanks Received:
    6,504
    If you do not have any bad indicators pay it off and then start putting that payment amount in an account every month. When you have 110% of the estimated overhaul reevaluate. If decide to overhaul go on vacation. The amount you would have spent on interest financing an overhaul is then a cash vacation. Some would go truck shopping keeping contacts and receipts. Then its a business expense.
    I always found large payments that come due ,taxes and such, easier with at least some set aside.
    Sounds like P. 2005 way have some good insight on those high mileage engines if answered but a gallon every 7500 miles would not concern me.
  6. peterbilt_2005
    May 4, 2013
    3,906
    Thanks Received:
    29,189
    Yup insight, doing inframe as I type this.
  7. lady doe
    May 25, 2014
    72
    Thanks Received:
    4
    MXS94989 YELLOW C15 TWIN TURBO REAR 336 O7 T2000
  8. lady doe
    May 25, 2014
    72
    Thanks Received:
    4
    NOT AT THIS TIME, JUST HOPING IT RUN GOOD UNTIL I SAVE UP ALITTLE MORE YOU KNOW. THE TRUCK RUNS GOOD IT JUST SMOKE SOME OUT OF THE OVER FLOW AND HAVE USE GALLON AND HALF OF OIL ABOUT 7 TO 8 THOUSAND MILES.. DONT KNOW HOW MUCH ONE WOULD COST AND WHO BE THE BEST TO FIX IT. DONT WANT ANEW TRUCK I HEAR MOST OF THE NEW ONE STAY MORE IN THE SHOP THAN THE OLD ONES WITH ALL THSI NEW STUFF THAT GOT IN THEM YOU KNOW. I EVEN HAD KENWOTHH DEALER TELL ME ON TIME JUST KEEP FIXING ON HE SEE WAY LESS OF THE OLD TRUCKS IN SHOP THAN THE NEWS. HE WAS VERY IMPRESSED WITH THE WAY MY TRUCK RAN AND THE UP KEEP ON IT. SO I WILL KEEP WHAT I KNOW RUNS GOOD FOR ME, IF IT NEEDS A REPAIR HEAR AND THERE SO BE IT.
    truckthatpassesyouby Thanks this.
  9. josh polk
    Dec 20, 2015
    142
    Thanks Received:
    64
    Bowie TX
    The MXS acerts have a lot more blow by than the a older C15 singe turbo until there is oil coming out with that smoke from that over flow (I refer to that as blow by (crank case pressure ) I wouldn't worry about it
    If any thing around 1.2millon miles if put rod and main bearings in it that will get u another 300k miles iv got two BXS that iv done this with no problems
    Not saying my advise is the best this is just my experience as a fleet owener not a Fan of BXS or MXS but u got the better of the two
    Just remember it's not just a truck u have to treat it like something u are madly in love with baby it around the truck stop parking lot ease it up to speed till u get in the high side make sweet love to it and it will b good and faithful to u and love u back hope this doesn't sound Inappropriate with u Bing a lady just what I tell my drivers
    Good luck
    God wont's us to receive his blessing
    God bless
  10. lady doe
    May 25, 2014
    72
    Thanks Received:
    4
    THANK YOU SO MUCH. JUST TRYING TO GET GOOD INFO YOU, THATS HELPS ME IN MY DECISION MAKING YOU KNOW, WE ALL OUT HERE TO MAKE MONEY AND HELP EACH OTHER OUT YOU KNOW. ALL TRUCK DRIVERS SHOULD STICK TOGETHER POWER IN UNITY.
