tips & ideas to get the hood up?
Discussion in 'Questions From New Drivers' started by msfern29, Mar 28, 2011.
  1. msfern29
    msfern29 Light Load Member
    Sep 23, 2010
    180
    Thanks Received:
    39
    SW Kansas
    I'm a small person, and I guess a weakling. I didn't have trouble with the trucks when I was at school, mostly newer model trucks.
    At my job, they have all macks, older models, and I'm not able to get the hood up by myself. Sometimes fenders full of mud & dirt, but not always. The guys who were willing to help me got laid off. Could use any tips or ideas on how to get the hood up by myself for pre-tripping the truck.
  2. ronin
    ronin Road Train Member
    Jul 22, 2008
    2,928
    Thanks Received:
    1,710
    San Antonio, Texas
    Is there those air inlet holes in the bumer where you can put in a foot to step up higher? I'm only 5'7", and when I weighed less than I do now, I had trouble getting some hoods open. That's all that worked for me.
  3. Force Fed Flesh
    Force Fed Flesh Light Load Member
    Jan 14, 2011
    61
    Thanks Received:
    37
    Long Island, NY
    One good way without having to open it from the front is undo both latches if it has latches, and grab the hood from the side above the drivers wheel and push straight up. I found it pretty simple on a freightliner century i was driving for many years. I barely ever opened it from the front. Pushing it up from the side gives you more leverage. Just make sure no ones standing around it so you dont smack anyone with the hood as you're opening it.
    --Anthony
    Powell-Peralta Thanks this.
  4. msfern29
    Sep 23, 2010
    180
    Thanks Received:
    39
    SW Kansas
    I can't get it to budge at all trying from the front. Tried using all my body weight, all it does is wiggle a little.
    I've tried pushing up from side, I'm 5'7'', and can only get it lifted to shoulder height, but can't get it pushed on up.
  5. Lilbit
    Lilbit Road Train Member
    Aug 4, 2008
    16,583
    Thanks Received:
    12,232
    Let me check my logbook
    Dang, that must be a heavy hood if you can't get it to budge with either method!
  6. Licensed to kill
    Licensed to kill Heavy Load Member
    Dec 31, 2010
    830
    Thanks Received:
    2,435
    Alberta
    Rather than the grabbing it from above the wheel, grab it from the bottom of the fender BEHIND the wheel down by the mud flap. You will have better leverage and more lift.
    Lilbit and Powell-Peralta Thank this.
  7. BigRigBamaTrucker
    BigRigBamaTrucker Light Load Member
    Dec 22, 2010
    188
    Thanks Received:
    84
    Prattville,Alabama
    ....your doing it wrong.:biggrin_25523:
  8. Flying Dutchman
    Flying Dutchman Road Train Member
    Nov 2, 2009
    1,274
    Thanks Received:
    522
    Northern California
    I would think a foot in the bumper hole would do the trick...
  9. Lilbit
    Aug 4, 2008
    16,583
    Thanks Received:
    12,232
    Always did for me, and I'm only 5'2" and weighed about 105 lbs soaking wet when I drove. :biggrin_25522:
    Flying Dutchman Thanks this.
  10. Flying Dutchman
    Nov 2, 2009
    1,274
    Thanks Received:
    522
    Northern California
    I know our newer Pete's dont have that single large hole in the front bumper, which I thought was stupid...until I tried to pull the hood and realized it had air assist lift shocks that really made it a breeze. Perhaps (if you are assigned one truck) the company could look into installing those for you? I can pull the hood of a new 388 standing on the ground with one arm.
