Tractor wont move with brakes released
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by KostaN, Feb 22, 2021.
  1. KostaN
    KostaN Light Load Member
    Feb 15, 2020
    57
    Thanks Received:
    18
    I need help
    After parking the truck overnight I fire up the truck put it in gear it wont move
    I thought the drums and pads are frozen but i hammered and torched all of them they seem fine...
    When I turn on the inter axle diff only two wheels are spinning but it wont move even an inch
    Any clues please
  2. AModelCat
    29,390
    Thanks Received:
    161,302
    Check that the 2 wheels that aren't spinning don't have frozen brakes still. If all the brakes are free, you're stuck. Chain up, throw sand or get a pull out of there.
    KostaN, cke and rachi Thank this.
  3. rachi
    rachi Road Train Member
    Feb 25, 2010
    4,246
    Thanks Received:
    5,231
    SoCal
    Ive had tires frozen to the ground a time or two.
    KostaN Thanks this.
  4. Atlaw4u
    Atlaw4u Heavy Load Member
    Jun 8, 2018
    750
    Thanks Received:
    1,131
    Maybe see if you can adjust and back the brakes off until you see a space between the pads and drum of the axle that is not spinning.
  5. 86scotty
    86scotty Road Train Member
    Aug 27, 2017
    4,634
    Thanks Received:
    12,607
    Appalachia
    What truck? My hill start assist solenoid died not long ago (on a bracket underneath the 5th wheel on my Volvo). It started doing that, locking up now and then. $100 part, easy fix.
  6. kemosabi49
    Jan 13, 2013
    10,901
    Thanks Received:
    47,292
    SW Arkansas
    no trailer?
  7. KostaN
    Feb 15, 2020
    57
    Thanks Received:
    18
    All brakes checked,pads moving
    Weather almost in the 50s
  8. 86scotty
    Aug 27, 2017
    4,634
    Thanks Received:
    12,607
    Appalachia
    You still didn't answer the question. What kind of truck, what year, etc.
  9. KostaN
    Feb 15, 2020
    57
    Thanks Received:
    18
    I do have trailer hooked,i tried with trailer
    I tried without same thing
    All pads moving up and down
  10. AModelCat
    29,390
    Thanks Received:
    161,302
    You're probably stuck then.
    lester Thanks this.
