Trailer Lights Malfunction Help
Discussion in 'Questions From New Drivers' started by Jgamboa, Oct 8, 2017.
  1. Jgamboa
    Jgamboa Bobtail Member
    11
    Thanks Received:
    5
    Good morning I'm having trouble with my lighting on my trailer every time I roll the Single loghts four-way lights and brakes lights don't function correctly and my abs trailer goes on in my cab and my relay it's getting hot and everyte I hit a bump the lights come back on or if sweave to the right and left when I which lanes but not all the time already took the trailer to get a check and nobody is to find the problem and they told the trailer is OK
  2. m16ty
    m16ty Road Train Member
    Jan 22, 2016
    2,266
    Thanks Received:
    4,947
    More than likely a ground problem. Don't know what advise to give other than check your grounds. Ground problems can make you pull your hair out.
    Jgamboa Thanks this.
  3. tinytim
    tinytim Road Train Member
    Oct 29, 2007
    5,143
    Thanks Received:
    18,260
    Northern Ontario
  4. tinytim
    Oct 29, 2007
    5,143
    Thanks Received:
    18,260
    Northern Ontario
    So they come on when you hit a bump. Is the pigtail connector loose where it plugs in to either the trailer or the cab? If you move the connector and the lights come on there's your problem. If not then it's probably a broken wire in one of the connectors, most likely the end that plugs into the trailer as that's the one that gets moved a lot.
    Lots of guys pulls on the wire when disconnecting from a trailer instead of grabbing the actual plug which will cause breaks.
  5. Jgamboa
    11
    Thanks Received:
    5
    I tried a new pigtail and he kept doing the same thing took the trailer twice already to get it checked but still nothing
    tinytim Thanks this.
  6. Opus
    19,247
    Thanks Received:
    120,113
    split the connectors....look at the picture above.....see how the pins have a little split in them? Take a pocket knife and stick it in that split and make them a bit wider....all of them
    tscottme and Jgamboa Thank this.
  7. Espressolane
    17,499
    Thanks Received:
    107,068
    Be very carful when you do this. Too much and you will break the pins.
  8. Opus
    19,247
    Thanks Received:
    120,113
    indeed.....they're brass and will break easily......just wedge them enough to split them and make better contact,,,,,mebee half way down the connector
  9. 1278PA
    1278PA Road Train Member
    Dec 5, 2015
    1,170
    Thanks Received:
    1,026
    I'm not trucker yet but i am an electrician. Sometimes relays build up crap on the contacts from the constant arcs overtime and also sometimes a reason of them getting hot. Hitting a bump can cause contacts not to stay open or closed. There are other relays in the fuse block that are the same most likely the AC relay you can switch it with. Obviously make sure the pins and numbers all match up before you switch them.
